Snapmaker 2.0 Firmware Updates and Downloads
Apr 27 2021: Snapmaker2_V1.12.1
Thank you for your suggestions on how to make the Snapmaker 2.0 better. Your feedback is always appreciated. Here comes the latest version of the Snapmaker 2.0 firmware.
Changelog
Controller
New Features
  • add “M413” G-code for enable/disable Power-Loss Recovery (#92)
    • Parameters
      • [S] S0/S1 for enable / disable Power-Loss Recovery
    • e.g. M413 S0 disable Power-Loss Recovery
  • add “M600” G-code for replace filament manually (#93)
    • You can add this G-code where you want to replace filament in .gcode file
Bug Fixes
  • Fix: Fix wrong value output with Enclosure lights and fan (#94)
  • Fix: Fix “M1006” G-code laser focus output with Snapmaker Luban (#95)
  • Fix: Fix X/Y coordinate of the first point in 3DP Calibration (#96)
  • Fix: Fix serial output messages in enclosure closing panel (#103)
Touchscreen
Improvement
  • Optimize copywriting in Origin Assistant
Downloads
Snapmaker2_V1.12.1
MD5: 3a2486f8eabf381b3bf4f1233fcd4289
Notes
This firmware update is only compatible with Snapmaker 2.0.
To see your current firmware version, go to Settings > About Machine .
How to Update Firmware
  • Via a USB flash drive
    • Put the firmware update file Snapmaker2_V{version}.bin in your USB flash drive.
    • Plug the drive into the Controller.
    • On the Touchscreen, tap Files > USB > Snapmaker2_V{version}.bin .
  • Via Wi-Fi
    • On the Touchscreen, tap Settings > Firmware Update .
    • Read the changelog and download the firmware.
    • After the firmware is downloaded, tap Update Now .
