SnapLinks -- Wiki
Having trouble editing this wiki, I’ll have a play off-line and see if I can clean it up so we don’t exceed the forum limits.
Meanwhile, for reference:
Under How to’s:
@Jameracho, A350 3D Printing Bed Calibration Guide - Google Doc
Section Added By Description External Resource
Things to make CthulhuLabs Accessory mount thingiverse.com
Things to make Leonardo Battery Boxes thingiverse.com
Things to make CthulhuLabs Bit Fan thingiverse.com
Things to make jstncrft Chess Puzzle Board thingiverse.com
Things to make freeman Easy Clamp for Snapmaker myminifactory.com
Things to make hank Cookie Cutters thingiverse.com
Things to make TheBum CNC Dust Fence thingiverse.com
Things to make Tone Dial Indicator Mount - SM2 thingiverse.com
Things to make doug Dust Cover thingiverse.com
Things to make Ardjan Filament Spool & Tool Holder thingiverse.com
Things to make jstncrft Filament Spool Adapter thingiverse.com
Things to make by Waldo Honeycomb Buzzle easy puzzle to print on SnapMaker myminifactory.com
Things to make Darren LEGO mount thingiverse.com
Things to make kelvin8r Minimal Spool Guide thingiverse.com
Things to make CthulhuLabs Part Cooler Shroud thingiverse.com
Things to make [Part Cooler Shroud 2 - Fractalengineer] thingiverse.com
Things to make Tone Part Cooling Shroud 3 thingiverse.com
Things to make kelvin8r Pi Camera Mount thingiverse.com
Things to make doug R2D2 Egg Cup thingiverse.com
Things to make doug Rotary Adapter thingiverse.com
Things to make Leonardo SnapBox thingiverse.com
Things to make Thingiverse Creater, royaljelly, waldo [Snapmaker Accessories Storage Box] thingiverse.com
Things to make doug Temperature Tower - Better thingiverse.com
Things to make lman Tool Storage seat aws1.discourse-cdn.com
Things to make kelvin8r Tool Storage 2 Z top thingiverse.com
Things to make jstncrft Universal Brackets thingiverse.com
Things to make Rick Vibration Dampers thingiverse.com
Things to make Various [A broad collection of projects for the Snapmaker at Thingiverse] thingiverse.com
CNC doug 2D Chinese Dragon aws1.discourse-cdn.com
CNC George Guy [Feeds & Speeds for Wood] cnccookbook.com
CNC Doug Parsons [Plastic Cutting CNC Router Bits] amanatool.com
Accessories Jihun Easy Clamp for Snapmaker myminifactory.com
Accessories doug Multi Color Filament Mixer mosaicmanufacturing.com
Accessories doug Multi Color Filament Mixer youtube.com
Accessories daemionfox Multi Color Print Head newatlas.com
Accessories daemionfox Multi Color Print Head reprap.me
Accessories kelvin8r OctoPi octoprint.org
Accessories kelvin8r [OctoPi - OctoPrint Forum] discourse.octoprint.org
Accessories kelvin8r [OctoPi - OctoPrint Docs] docs.octoprint.org
Accessories Tone Nickle Plated Nozzle amazon.com
Accessories [Touchup Tool] amazon.com
Accessories [Touchup Tool Lower Cost] amazon.com
Software Tone [Free Block Drawing Program] app.diagrams.net
Software Tone [Free Block Drawing Program] youtube.com
Software doug [FreeCAD Manual:Preparing models for 3D printing - an interesting read, especially on converting to Meshes] freecadweb.org
How To xchrisd 3d Print Guide_Walk Through
How To Jameracho A350 3D Printing Bed Calibration Guide Google Doc
How To doug [Cura Tutorial] all3dp.com
How To doug [Best Glues, Epoxies, and Plastic Welds for 3D Printing - Part 1] youtube.com
How To doug [Getting started with Fusion 360 - a good video to start learning from] autodesk.com
How To doug [Fusion 360 - Tutorial for Absolute Beginners— Part 1] youtube.com
How To doug [Fusion 360 - Tutorial for Absolute Beginners— Part 2] youtube.com
How To doug [Fusion 360 - Tutorial for Absolute Beginners— Part 3] youtube.com
How To doug [Fusion 360 - Foundation Concepts - A series of great short video’s] help.autodesk.com
How To doug [Fusion 360 - How to create embossed text] youtube.com
How To doug [Fusion 360 - Split Face & Split Body] youtube.com
How To doug [How To - Avoid clogs with PLA Composites and all-metal hotends] proto-pasta.com
How To doug [How to Smooth PLA 3D Prints] instructables.com
How To doug [How to Anneal Your 3d Prints for Strength] rigid.ink
How To doug [How to find the perfect temperature for your 3D prints!] youtube.com
How To doug Painting with Oil Based Pens youtube.com
How To Tone [Printing with Nylon] matterhackers.com
How To doug Working with PLA Filament rigid.ink
How To doug [The Ultimate Guide to 3D Printed Text] thingiverse.com
How To doug [The Ultimate Guide to 3D Printed Text] xometry.com
How To doug [THE ULTIMATE BEGINNERS GUIDE TO 3D PRINTING] beginnersguide.io3dp.com
How To doug [3D Printing Tech Tips: Infill Percentage and Pattern Explained] 3dplatform.com
How To doug Temperature Towers - FINDING THE PERFECT TEMP FOR ANY FILAMENT youtube.com
How To doug [Simplify3D - Improved 3D Printing Success!] youtube.com
How To doug [Picking a 3D printer nozzle and installing it!] youtube.com
How To doug [Simplify3D - Different Settings for Different Regions of a Model] simplify3d.com
How To doug [Over-Extrusion – Tips and Tricks to Solve It] all3dp.com
How To doug [3D Printing 101: How To Fix a Clogged Nozzle Using a Cold Pull! - Suggested by James Bricknell] youtube.com
How To doug [Annealing PLA Prints for Strength – 2 Easy Ways] all3dp.com
How To doug [3D Printer Bed Adhesion – All You Need To Know] all3dp.com
How To doug [How to Set Up OctoPrint on Raspberry Pi 3 B+ – 3 Easy Steps] all3dp.com
How To Doug Parsons [TinkerCAD - YouTube Channel] youtube.com
How To Snapmaker [How to Use the Laser Engraving Feature?] youtube.com
How To Snapmaker [How to Use the CNC Feature?] youtube.com
How To Snapmaker Remove Blob
How To Snapmaker Laser settings for different materials
How To Snapmaker Cleaning the Linear Module
How To Snapmaker Leveling the Heated Bed
How To Snapmaker What should I do if the filament is broken in the 3D Printing Module?
How To Snapmaker What should I do if the first layer does not stick to the heated bed?
How To Snapmaker What should I do if the laser engraving module cannot work anymore?
How To doug [The Best Way to 3D Print Threads; Nuts, and Bolts] youtube.com
How To doug [Step-by-step easy guide: designing and 3D printing threads] sculpteo.com
How To doug [3D Printing Threads and Screws – A Simple Guide] all3dp.com
How To Edwin SnapMaker Original Repair Tutorial
Source code Snapmaker Announcement github.com
Source code Tone [G-code Wiki] reprap.org
Source code Tone [G-code Wiki] marlinfw.org
Source code Tone [Releases - The most current Luban] github.com
Source code Snapmaker [Snapmaker G-code Google Docs Reference (incomplete)] docs.google.com
Troubleshooting rojaljelly [Troubleshooting] aprintapro.com
Misc Tone [36 Colors PLA - 16’ each - Includes 6 Glow in the dark] amazon.com
Misc doug [3D Printer Nozzle Comparison Guide] matterhackers.com
Misc jstncrft Filament Tube amazon.com
Misc doug [ABS Bed Adhesion Tips & Tricks] matterhackers.com
Misc rojaljelly [Filament Properties Table] simplify3d.com
Misc doug [Free ‘Beginner’s Guide to 3D Printing’] i.materialise.com
Misc doug [Complete 3D Printing Filament Comparison Guide - 2018] rigid.ink
Misc doug [PLA Filament Guide 2018 – Explained & Compared] all3dp.com
Misc doug [Complete 3D Printing Filament Comparison Guide 2019] rigid.ink
Misc doug [Print Quality Troubleshooting Guide] simplify3d.com
Misc doug [Reviewing 30 different filaments!] toms3d.org
Misc zeveck USA Made PLA – looks to be good quality PLA makergeeks.com
Misc doug [Starter Temperatures & Printing Guide] filaments.ca
Misc doug [Octin Stencil] dafont.com
Misc doug [Octin Prison] dafont.com
Misc doug [Ultimate 3D Printing Materials Guide] simplify3d.com
Misc doug [When should you upgrade the nozzle in your 3d printer?] youtube.com
Misc doug [The 3D Printer Filament Recycler’s Guide] all3dp.com
Misc doug [Laser Safety] wickedlasers.com
Misc doug [3D Printer Nozzle Size & Material – What to Know & Which to Buy] all3dp.com
404 Error Tone SparkMaker – SLA printer shop.ogadget.com
Just realised that nobody can actually see the source for my suggested reformatting :frowning:
I had a go at reformatting the wiki, I copied the original into a spreadsheet, attempted to move stuff around so it was in a consistent location, then added standard layout and cleaned up some of the links.
@Tone if you’re agreeable - as the original author, and because I don’t know if there’s a revision history of the wiki, would you like me to copy/paste my post into the main body of your post, replacing its content?
Update: A few of us have been playing with this layout – this is still a work in progress.
There is a revision history. It’s right at the top right of the original post, It’s currently at 100 with a little pencil and paper icon. After clicking on it you can scroll thru the various versions with controls at the bottom. (Unless that’s only available to me as the original author. ) But I do think it was clickable before I logged in.
@Tone
Excellent job. Well done.
John Fiott
Thanks for making this list. As a new user and a first time owner, I am sure that this will be a great resource!
I appreciate the How To but it doesn’t seem to match what I have with the A350. My calibration card does not have a black dot on either side. Also, it’s unclear how to adjust settings while laser is running when using the flash drive. I have been unable to connect to my SM via wifi so I’m sorta left with the flash drive and manual mode.
if there are any new HOW TO’s on this I would sure like to see it.
thanks
You can refer to this article.
Snapmaker 2.0 Laser Engraving and Cutting V1.1.0 – Snapmaker
