Snapmaker Luban Downloads and Updates
August 18, 2021: v4.0.0
Here comes the Snapmaker Luban 4.0!
In Snapmaker Luban 4.0.0, we bring a new designed UI and cleaner workflow that fits Luban’s versatile usages. Printing settings for all 3 functions (3D Printing, Laser and CNC) are reworked too, and we now have a separate job setup panel and unified printing settings (tool path settings).
Brief changelog:
  • Brand new designed user interface which is more modern and precise.
    • Added Home page to navigate among different workspaces, and 3-axis and 4-axis workspaces are split.
    • Added Main Toolbar on top for quick access to frequently used tools.
  • Refined workflow (mainly for Laser and CNC G-code Generator).
    • Added Beginner’s Guide.
    • Added Job Setup panel for Laser and CNC workflows.
    • Unified toolpath settings for consistency.
    • Added General Parameters panel to display commonly used parameters, and you can also customize the visibility of parameters.
    • Added default profile for PETG material
    • Reworked Undo and Redo feature.
  • Re-implemented slice backend in C++ to have a great performance improvement on toolpath generation.
For the full user manual for Snapmaker Luban 4.0, please checkout Snapmaker Luban 4.0 User Manual. Your feedback is very much appreciated. If you have encountered any problem or would like to propose suggestions, contact us via one of the following:
Downloads
Snapmaker Luban for macOS
Snapmaker Luban for Windows 64-bit
For Linux versions and Windows 32-bit versions, please refer to our Github releases page to download.
August 23, 2021: v4.0.1
Changelog:
  • Fix: Fix 3D model uniform scaling not working.
Dec 13, 2021: v4.1.1
Brief changelog:
  • Modified default 3D printing profiles for easier first layer adhesion #1310.
  • Improved G-code execution time estimation (3DP, laser, CNC).
  • Added CNC tool profile “Single Flute 3.175mm”.
  • Improved i18n translations (EN and ZH-CN).
  • Added F250 and F350 machine selections.
For Luban v4.1.0-beta.1, please checkout https://github.com/Snapmaker/Luban/releases/tag/v4.1.0-beta.1 as well.
Changelog lists below:
  • Added support for 10W High Power Laser Module, including Auto Focus feature, upgraded Camera Capture feature, and updated Case Library .
  • Added STL to SVG support for laser cutting.
  • Extended pre-defined profiles with recommended parameters for common laser materials.
  • Added “Rotate on Face” on rotation panel with sugguested faces, you can choose placement face based on Overlap Area and Support Volume required.
  • Derived G-code preview from workspace to separated popup window.
  • Added auto Wi-Fi connect and several built-in Macros for querying machine state.
  • Added (brought back) multi-line text and alignment options.
  • Improved text font parsing.
  • Fixed Console unable to copy/paste on macOS.
  • Fixed irregular font ratio and irregular image width/height ratio.
For the full user manual for Snapmaker Luban 4.0 and later, please checkout Snapmaker Luban 4.0 User Manual.
Download links
December 26, 2021: v4.1.3
Note: This release will not clear your custom 3D printing configurations.
Brief changelog:
  • Fix: Fixed custom configuration loss issue in v4.1.
  • Fix: Fixed wrong Laser job start position when using the Automatic Mode (with user input material thickness) via serial port.
Download links
Mar 15, 2022: v4.2.2
Brief changelog:
New features
  • Feature: Added Dual-extruder support.
  • Feature: Added 3D model group and ungroup functions in 3D printing editor.
  • Feature: Added " Align " function to position several models together in their design position.
  • Feature: Added model " Auto arrange " function with rotation and spacing parameters.
  • Feature: Added automatic back up for user configuration data.
  • Feature: Added printable area display. Printable area is changed according to adhesion type and extruder selection, and highlighted on build volume.
Improvements
  • Improvement: Added pop-up windows to notify user that export is completed.
  • Improvement: Migrated " Extrusion " parameters to materials, allowing users to customize extrusion parameters by material.
  • Improvement: Enhanced support tools with optimized manual support.
  • Improvement: Optimized 3D model rendering.
  • Improvement: Optimized the startup speed of the software.
  • Improvement: Optimized the performance of batch process image and preview G-code(Updated Electron to 11.5.0).
  • Improvement: Updated translations for six languages.
  • Improvement: Re-added a pop-up window prompts when SVG/DXF image is too large.
  • Improvement: Revised the default value of " number of passes " when changing the Toolpath processing method in laser editor.
Bug fixes
  • Fix: Fixed that the connection to the machine was easily disconnected due to the main process being stuck.
  • Fix: Fixed UI bug that 3D printing G-code layer view starts from layer 1 instead of layer 0.
  • Fix: Fixed a bug that extra straight lines being printed right after resuming printing (under the serial port).
  • Fix: Fixed a bug that you can click " Send file to machine " button when G-code file is not selected.
  • Fix: Fixed slice issues after switching process mode from vector mode to bitmap mode in laser editor.
  • Fix: Fixed UI text not being displayed correctly with specific system fonts (e.g. Zapfino-Regular font) (feedback from user ticket).
  • Fix: Fixed some buttons in workspace control panel cannot be clicked (feedback from user ticket).
  • Fix: Fixed UI does not updated when changing the general parameters in some special case in laser&cnc editor. (feedback from user ticket).
Known issues
  • " Scale to fit " feature is not working as expected in some case in 3D printing editor.
Download links
Feedbacks
Thanks to @maihde @Minimieo for his contributions to this release.
Apr 9, 2022: v4.2.3
Snapmaker Luban v4.2.3 is a bugfix version.
Brief changelog:
Bug fixes
  • Fix: Fixed " Fan Speed " parameter not taking effect in 3DP editor
  • Fix: Fixed " Initial Layer Printing Temperature " parameter not taking effect in some case in 3DP editor
  • Fix: Fixed after checking the " General Parameters " of the ‘retraction’, the ‘retraction’ parameter will still be displayed in " General Parameters " after upgrade.
  • Fix: Fixed changing the nozzle color not syncing with the color of a model (with manually added supports).
  • Fix: Fixed incorrect slicing results for duplicating modified built-in text in Laser & CNC editor.
  • Fix: Fixed blank when right-clicking an object for the first time to duplicate or copy in Laser & CNC editor.
  • Fix: Fixed slicing multiple built-in rectangles getting stuck in Laser editor.
  • Fix: Fixed some UI bugs.
Known issues
  • " Scale to fit " feature is not working as expected in some case in 3D printing editor (Will be fixed in v4.3.x)
Download links
Feedbacks
Sep 20, 2022: v4.4.0
Brief changelog:
New features
  • Featrue: Added material parameters and printing parameters up to 290+
    • New quick parameter setting interface
    • Enhanced parameter management interface
    • Variety of parameter display modes
    • Detailed parameter explanation
  • Feature: Added 3MF, AMF support in 3D printing/Laser/CNC editor
  • Feature: Added Model Repair and Model Simplification
  • Feature: Added Simulation Preview with volume in 3D printing editor
    • Takes more time to generate the preview
    • Simulation preview will not be displayed when insufficient memory is detected, but G-code can still be exported
  • Feature: Quick preview of some parameters before slicing
    • The preview results will be partially different from the slicing results
  • Feature: Default print configuration tied to material and nozzle diameter
  • Feature: Added workflow to publish releases to Windows Package Manager
Improvements
  • Improvement: Optimized the style and interaction of 3D Canvas
    • Optimized zoom-in operation and pan operation after zoom-in operation
  • Improvement: Supported to use backup mirror of software auto-update when access of github releases is limited
  • Improvement: Optimized vector machining paths for Laser and CNC
  • Improvement: Set the Auto Connect button in the workspace tab to unchecked by default
Bug fixes
  • Fix: Fixed incorrect parsing of SVG with nested text elements
  • Fix: Fixed the possible wrong position of using the up and down key shortcuts for objects with rotation in Laser/CNC editor
  • Fix: Change the timing of the completion of printing is defined as completion rather than the last G-code sent
  • Fix: Fixed extrusionDirection attribute of DXF not being parsed
  • Fix: Fixed incorrect parsing of SVG float numbers
  • Fix: Fixed the problem that when has moved after paused, printing was not resumed from the position before the move in Laser and CNC
  • Etc…
Known issue
Detailed UI changes and new features can be found on our Blog: What’s new in Snapmaker Luban v4.4.0 - Snapmaker Blog
Download links
Feedbacks
For the full user manual for Snapmaker Luban 4.0 and later, please checkout Snapmaker Luban 4.0 User Manual .
Jan 12, 2023: v4.5.0
Brief changelog:
Main Features
  • Engine Upgrade: Upgrade slicer to support new features
    • Variable line width
    • Lightning infill
    • Monotonic top/bottom order
    • Nozzle Heating Wait Time and Temperature Threshold
    • Added M2000 IDEX seamless head change
  • Refined Print Settings Panel
  • New machine definitions & profiles: J series & Artisan & SM2.0 Dual Extruder
    • Added J series definitions & profiles & user case
    • Added Artisan profiles & user case
    • Update SM 2.0 Dual extruder profiles
    • Added pre-process of area bed heating for Artisan
For detailed changelog, please checkout Release v4.5.0 · Snapmaker/Luban · GitHub
Download links
We provide Snapmaker Luban for different platforms:
  • macOS x64/ARM64
  • Windows x64/ia32
  • Linux
Please refer to our Github releases page to download.
Feedbacks
Jan 19, 2023: v4.5.1
Brief changelog:
Note:
  • Added support for macOS with M1 chip
  • Remove support for Windows ia32
  • Remove support for macOS 10 (Catalina, Mojave, High Sierra), please upgrade to at least macOS 11
Bug fixes:
  • Fix: Fix printer auto connect bug that causes bed hitting
  • Fix: Fix SVG distort issue
  • Fix: Fix linux executable by adding --no-sandbox option
  • Fix: Remove SM 2.0 prepend G-code settings
  • Fix: Fix broken anchors on parameter table
  • Fix: Fix wrong display of toolhead in Settings - Machine settings page
  • Fix: Fix prime tower X/Y scale reset
  • Fix: Add guard for reading broken preset files
  • Fix: Prevent laser job from working with invalid focal length
  • Fix: Fix missing quality preset from old project file
Improvements:
  • Improvement: Update support print settings
  • Improvement: Update M140 M to M140 P
  • Improvement: Update German translations
  • Improvement: Update Ukrainian translations
Download links
  • macOS x64/ARM64
  • Windows x64
  • Linux
Feedbacks
Apr 19, 2023, v4.7.3
System Requirements
  • macOS >= 11, for legacy macOS 10 versions (Catalina, Mojave, High Sierra), please upgrade to at least macOS 11
  • Windows x64
  • Linux 64 bits distros
What’s Changed
Improvements
  • Added Unit Support: Now supports inch, centimeter, and meter units for 3MF files.
  • Updated Print Settings: Improved settings for dual extruders to reduce clogging issues.
  • Expanded Initial Layer Flow Parameters: Provided access to modify initial layer flow settings.
Fixes
  • Quality Preset Issue: Resolved issue with created quality presets missing properties.
  • G-code Generation: Fixed problem with generating G-code upon changing right extruder parameters.
  • Prime Tower Calculation: Corrected prime tower calculation error when no mesh is present in the scene.
  • Faceless Geometries: Addressed issue with faceless geometries appearing in the scene.
Full Changelog: v4.7.3
Download links
  • macOS x64/ARM64
  • Windows x64
  • Linux
Feedbacks
May 25, 2023, v4.8.0
System Requirements
  • Windows x64
What’s Changed
New Features
  • Introduced mesh coloring tool & multi-color model slicing.
  • Launched an online case library.
  • Added simple mesh split tool.
Improvements
  • Added printer control functions (nozzle & heated bed control) for J1 & Artisan printers.
  • Updated print setting profiles with reduced minimum layer time.
Bug Fixes
  • Fixed issue with the transfer file name.
  • Fixed issue where the G-code thumbnail includes hidden objects.
  • Restored missing progress bar for preview.
  • Fixed incorrect estimated print time calculation.
Mesh Painting Tool & Multi-color Model Slicing
In response to user requests, we have now added Mesh Painting Tool & Multi-color Model Slicing similar to PrusaSlicer’s Multi material painting.
In GUI, you can apply two distinct colors to the mesh, each representing two different materials.
To support this new functionality, we have adapted our slicing engine, ensuring it can handle the slicing of these newly colored meshes.
Luban provides two tools, Smart Fill and Brush, to accomplish mesh coloring.
  • Smart Fill: Depending on the angle of the triangles in the clicked area, select triangles with a range of angular tolerances around the connection.
  • Brush: Triangles are selected based on the triangles and angular tolerances that the spherical brushes come in contact with. Smaller angle tolerances detect sharp borders, allowing the brush to paint only the area within the edge. The opposite is true for larger angles, where a 90° tolerance allows the brush to recede to select all triangles touched by all spherical brushes.
In terms of shortcut operations, it supports numbers 1 and 2 to switch color selection quickly, and Ctrl/Command + scroll to quickly resize the brush.
The undo feature and preview of colored areas are still under development. They will be completed in future versions.
Model Split Tool
For models that are composed of multiple meshes, they can naturally be assigned to different extruders without the need for coloring. In that case, we provide a split tool that allows you to split a single STL file composed of multiple meshes. This makes it easier to allocate different extruders to each segment.
Online Case Library
Considering the scarcity of multi-material models, we have created an online case library to share models suitable for multi-material printing. Currently, the resource quantity is limited, but we will gradually increase it. In the future, we plan to add sections for Laser and CNC, and make it accessible to everyone.
Full Changelog: v4.8.0
Download links
  • macOS x64/ARM64
  • Windows x64
  • Linux
Feedbacks
June 26, 2023, v4.8.1
System Requirements
  • Windows x64
What’s Changed
Improvements
  • Added SM2.0 Quick Swap Kit detection
  • Added J1s machine and adjusted parameters for J1/J1s
  • Added Quick clear mesh painting in object list
  • Added Dual material interlock parameter
  • Optimized mesh painting slicing speed & interaction
Bug Fixes
  • Fixed the issue where default presets could not be selected for certain material types.
  • Fixed the issue where mesh painting slicing results were incorrect when the model was assigned as a right extruder.
  • Fixed the issue with some initial layer parameters being in the wrong directory.
  • Fixed the issue with abnormal saving of certain print configuration parameters.
  • Fixed the problem of some models failing to slice.
  • Fixed the issue where objects could not be selected and deleted in Laser and CNC modes.
  • Fixed the problem of Prime Tower not being automatically generated in certain cases.
  • Fixed the software crash issue caused by using the pen tool.
  • Fixed the issue where coloring STL files was not saved in the project file.
  • Fixed the issue where 3D printing slicing would generate extra skins.
  • Fixed the problem of J1 Console not being available.
  • Fixed the issue of Laser and CNC toolpaths getting stuck.
  • Fixed the issue where 3D Gizmos would disappear after use.
  • Fixed the problem of confusing material type content.
  • Fixed the issue where Laser toolpaths could not be generated on Linux systems.
Full Changelog: v4.8.1
Download links
  • macOS x64/ARM64
  • Windows x64
  • Linux
Feedbacks
July 17, 2023, v4.8.2
System Requirements
  • Windows x64
What’s Changed
Bug Fixes
  • Manual Support Generation: Resolved an issue causing abnormal behavior during manual support generation.
  • Chinese Display: Fixed an abnormality in the display of the release note in Chinese.
  • Image Processing: Solved the problem of white edges appearing after image processing.
  • Dual Extruder Control: Rectified an abnormality in the control of dual extruders.
  • Slicing Issues:
    • Fixed an issue that was causing extra skin in slicing.
    • Addressed a problem causing slicing failure in certain scenarios.
  • Parameter Modification: Corrected an abnormality that occurred during parameter modification in some cases.
  • Windows 7 Compatibility: Resolved a software behavior abnormality present in some Windows 7 systems.
Known Issues
  • The control of dual extruder module in SM 2.0 is based on the current nozzle.
Full Changelog: v4.8.2
Download links
  • macOS x64/ARM64
  • Windows x64
  • Linux
Feedbacks
Sep 19, 2023, v4.9.0
Note: Since this version of Luban fully supports inline mode on the laser, this requires SM 2.0 and Artisan to upgrade their firmware to the latest.
New Machine & Module Support
  • Snapmaker Ray:
    • Machine definitions and print presets.
    • Dedicated workspace.
  • 20W & 40W Laser Modules:
    • Print settings for SM 2.0 and Artisan.
Features & Improvements
  • Vector Enhancements:
  • Job Setup:
    • Introduced “Object” origin type for Laser/CNC G-code generation.
  • Home Page:
    • Enhanced news feeds.
  • Artisan Extruder:
    • Implemented work range limit for the left extruder when not exclusively using the right extruder.
  • Display
    • Low gamma screen compatibility
    • Added preview auto zoom fit
Parameter Additions
  • Laser Parameters:
    • Introduced greyscale conversion & none dithering option.
    • Introduced inline mode for image engraving.
    • Introduced constant power & trapizoid power.
    • Introduced half diode mode (for 40W laser module only).
  • 3D printing Parameters:
    • Introduced “Fuzzy Skin” parameter
Bug Fixes
  • Fixed unexpected white edges in images.
  • Corrected G-code starter code for rotary modules.
  • Resolved 3D auto nesting and tool head recognition issues on SM 2.0.
  • Addressed issues with project opening crashes, workpiece settings, canvas scaling, SM 2.0 camera capture, and pointer focus.
  • Improved time calculation accuracy.
  • Text is replaced when selected.
Known Issues
Full Changelog: v4.9.0
Download links
  • macOS x64/ARM64
  • Windows x64
  • Linux
Feedbacks
Sep 27, 2023, v4.9.1
Bug Fixes
  • Fixed point engraving mode use of M4
  • Fixed wrong G-code flavor used in vector point engraving mode (for SM 2.0 and Snapmaker Artisan)
  • Fixed connection issue of Snapmaker Original
  • Fixed console does not reply “ok” when executing G-code
Known Issues
Full Changelog: v4.9.1
Download links
  • macOS x64/ARM64
  • Windows x64
  • Linux
Feedbacks
Nov 15, 2023, v4.10.1
Laser Parameter Additions
Snapmaker Luban v4.10.0 updated the engraving parameters for pictures and graphics. With finely tuned parameters, intricate patterns and complex designs can now be engraved with greater accuracy.
  • Dot Width Compensation is able to optimize the toolpath based upon the size of the laser dot to reduce contour deformation and blurs.
  • Over Scanning is used to solve under and over burns from acceleration and deceleration phases.
  • Scanning Offset designed to reach better results in cases where there is a large mechanical backlash or when the design to be engraved is intricate with rich details.
  • Feature: Add Ray firmware upgrade via network
  • Feature: Add error report handling for Ray
  • Improvement: Improve 20W & 40W laser module material preset
  • Improvement: Add $H home button to ray set origin widget
  • Improvement: Use error report message
  • Improvement: Use 0.2% laser power for 20W & 40W laser module test laser
  • Improvement: Add option to keep the laser on when moving
Full Changelog: v4.10.1
Download links
  • macOS x64/ARM64
  • Windows x64
  • Linux
Feedbacks
Jan 16, 2024, v4.10.2
Note: Since Luban fully supports inline mode on the laser, this requires Snapmaker 2.0 and Artisan to upgrade their firmware to the latest.
  • Improvements: The minimum line interval in Laser fill limit is changed from 0.05 to 0.01.
  • Improvements: Associated adhesion type parameters to support brim parameters.
Bug Fixes
  • Fix: Unable to use the support tool in 3D Printing.
  • Fix: Abnormal size parsing of SVG/DXF/images.
  • Fix: Unable to import Stl/3mf files into Laser/CNC.
  • Fix: In certain situations, serial ports for Original, SM2, and J1 machines cannot connect.
  • Fix: Unable to generate toolpath after opening laser project files generated by old versions.
  • Fix: Abnormal model size when opening 3D Printing project files.
  • Fix: Incorrect display of rotation module and other Add-ons in Ray Wi-Fi connection.
  • Fix: Abnormal boundary code in Ray rotation module.
  • Fix: When Ray uses the point fill method, the border does not run correctly.
  • Fix: Content error in svg-text input boxes.
  • Fix: Sending file exception caused by empty G-code filename.
  • Fix: J1 connection incorrectly displayed exhaust fan issues.
  • Fix: Some copywriting error.
Download links
  • macOS x64/ARM64
  • Windows x64
  • Linux
Feedbacks
March 7, 2024, v4.11.0
Note: Since Luban fully supports inline mode on the laser, this requires SM 2.0 and Artisan to upgrade their firmware to the latest.
  • Feature: Bracing Kit for 2.0 support.
  • Feature: 200W CNC for 2.0 support.
  • Improvement: Remove Go home Modal after resume printing
Bug Fixes
  • Fix: In certain situations, camera capture and add a background, the print position is not correct.
  • Fix: After selecting the A250/A350 disassembly kit, the Z-axis did not decrease by 15mm.
  • Fix: Snapmaker 2.0 serial connection, CNC toolhead status not same as machine.
  • Fix: Snapmaker 2.0 serial connection, without turn off toolhead after stop printing
  • Fix: Can’t edit gcode’s name after wifi connecting
Download links
  • macOS x64/ARM64
  • Windows x64
  • Linux
Feedbacks
May 14, 2024, v4.12.0
  • Feature: Add support for the Snapmaker 2.0 dual extruder module on the Artisan.
  • Improvement: Update 200W CNC profile
Bug Fixes
  • Fix: Choosing different modules affects the workspace layout (x, y axis).
  • Fix: In certain situations, completed jobs are not marked as completed in the UI
  • Fix: Right nozzle temperature default value is now set to the target temperature (same as left nozzle)
  • Fix: Module information may interfere with each other when connecting to different machines without refreshing Luban.
Download links
  • macOS x64/ARM64
  • Windows x64
  • Linux
Feedbacks
June 18, 2023, v4.13.0
Feature
  • 2W Laser Module (2W Infrared Laser Module) compatible with (WiFi and Serial):
  • 2W Laser Module Default Laser Profile
  • A-B Position (support for 20W,40W,2W Laser Module)
    • Operation Steps: After connecting the machine, open the AB Position panel. Use the panel to control the module’s positioning to the rectangular lasering area. After clicking the panel’s completion button, the canvas will highlight the lasering area, and you can print based on the position information on the canvas.
    • Note: It is worth noting that AB Position is essentially a generated ordinary G-code, just its work-origin is the mechanical coordinate point (0, 0). After completing AB positioning and resetting the work-origin, you need to redefine the worki-origin as the mechanical coordinate point (0, 0), or click the AB positioning panel’s completion button again to set it automatically - this will set the working origin to the mechanical coordinate point (0, 0).
      It is worth noting that AB Position is essentially a generated ordinary G-code, but its work origin is set to the machine coordinate point (0,0). If the work origin is redefined after completing AB position, the work origin of the AB position G-code (i.e., the machine coordinate point (0,0)) will be overwritten. You will need to redefine the work origin to the machine coordinate point (0,0), or you can click the “Done” button on the AB position panel again to automatically set the work origin to the machine coordinate point (0,0). Otherwise, the laser processing may fail.
  • Ray Add Control Mode.
    • Note:
      • Maintain Motor Power-on Mode: When you enter this mode, the machine’s execution head will be in a powered-on state, and it cannot be pushed during this time.
      • The G-code generated under control mode must be executed while the machine is in the power-on mode. Conversely, the G-code generated under manual mode must be used while the machine is not in the power-on mode
  • CNC 4mm tool Engrave Profile added.
Improvements
  • Improvement: 200W CNC Module Default Engrave Profile.
  • Improvement: Artisan machine settings, hide dual-extrusion for Snapmaker 2.0 select feature for better user experience.
  • Improvement: Artisan 20W and 40W Laser Module input material Thickness print.
  • Improvement: Artisan 20W and 40W Laser Module will turn off crosshair light after start cutting or engraving.
  • Improvement: SM2 auto turn off laser after machine disconnected (The disconnection was initiated by Luban).
  • Improvement: Added and improved Chinese and German language support for the software interface.
Bug Fixes
  • Fix: Filled-Line gcode go to laser position with workpeed instead of jogspeed.
  • Fix: Reconnected machine will clear pre-states: modules and cameracapture.
  • Fix: Saving laser project file will contain auxiliaryAirPump, halfDiodeMode, constantPowerMode, initialHeightOffset.
  • Fix: Can not select model after using Rotate on Face (3DP).
  • Fix: Issue with rotating module running border on the B-axis with a value of 0 in specific contexts.
Download links
  • macOS x64/ARM64
  • Windows x64
  • Linux
Feedbacks
