Sep 1 2020: Snapmaker2_V1.10.1
Thank you for your suggestions on how to make the Snapmaker 2.0 better. Here comes the latest version of the Snapmaker 2.0 firmware. Your feedback is always appreciated.
Changelog:
Main Controller
Bug Fixes
- Fix a bug where the machine stops at 99% when 3D printing.
- Filament would extrude properly after resuming from Pause or Power-Loss Recovery.
Improvements
- Thermal protection is optimized to avoid accidental triggers.
- Confirm if Power-Loss Recovery is normal during controller bootup.
- Pre-heat the nozzle to 150℃ before it raises up from the print after resuming from Power-Loss Recovery.
- Lower the initial height of the nozzle after Auto Leveling.
- Raise 3mm for the initial height of the nozzle in Manual Leveling.
Downloads:
MD5: 6addea2ecc4a06ed07c138dfa4b3a502
Notes:
This firmware update is only compatible with the Snapmaker 2.0 devices.
You can check the About page for the firmware version after the upgrade.
How to update Firmware
- via a USB flash drive
- Put the firmware update file Snapmaker2_V{version}.bin in your USB flash drive.
- Plug USB into the USB slot of the Controller.
- On the touchscreen, tap Files , select the update file under the USB tab to start the update.
- via Wi-Fi
- Tap Settings -> Firmware Update on the touch screen.
- Read the changelog and download the firmware.
- After the firmware is downloaded, click “Update Now” to start the update.
