Wi Fi connection failure
Unable to connect to the printer via Wi-Fi.
I also tried entering the IP address into Luban, but it didn’t work. Everything freezes, as shown in the attached screenshot.
1.Check if your router is overheating, then restart it.
2.If the issue persists after refreshing, try unbinding and re-binding the machine and software!
I’ve tried all these solutions, but the problem persists.
I’ve reset my computer and reinstalled the software, but it doesn’t work. I’ve also disabled the firewall…
Be sure you are connected to the same WiFi ( mine has a 2.4G and a 5G band, which is at least for me different).
Try deleting the cache of Luna (maybe backup before delete?)
Only now did I realize I misread your printer model.
WiFi has a 2.4G band.
I tried also to cancel the folder but it doesn’t work.
Need to solve asap…. Thanks a ot for your help.
Not really solving your WiFi issue, but a potential workaround: Use Ethernet cable with adapter: Connecting Artisan via LAN
I paid for the Wi-Fi feature and I need it. I’m waiting for official support from Snapmaker. Are there any other possible solutions? The problem persists.
Try the latest beta firmware and send your gcode from Snapmaker orca, could be a possible solution if Luban does not work on your pc:
I found the SN 2.0 was fussy about WiFi strength, even when it was able to see the wifi and connect. I had to move a wifi repeater closer in order to achieve reliability.
