It’s quite strange; my U1 3# feed port can automatically feed 85A and 90A TPU directly, but when feeding from port 4#, the material gets卷进去 (rolled in) and cannot be fed. Has anyone else encountered a similar issue?
Only half a reply: AFAIK, you can adjust the tension in the toolhead. People did say that they have adjusted that to print TPU. I can only aassume that 1-3 were ok and #4 too tight. But I don’t know right now, where this can be done. Someonelse jump in, please … minutes later.. found some reference to tension screw here. https://www.facebook.com/groups/snapmakeru1/permalink/1164501649087213/
Harder TPU can go through the auxiliary feeder directly. If only Toolhead 4 isn’t working, try adjusting the hex socket screw on the side of the toolhead to loosen the tension spring (clockwise to loosen, counter-clockwise to tighten).
And it would be nice if people would reply here once in a while.
Check the Snapmaker Wiki for the U1 has a ton of useful information. Everyone with a U1 should have it bookmarked.
My current choices are 3# 85A and 4# 95A. In fact, the demand for multi-color TPU printing is not very high. I think the current situation is acceptable. On the other hand, it proves that direct printing of flexible materials is not impossible; it just requires some accessory modifications or parameter adjustments.
