How to Submit a Ticket for U1 Customer Service or Technical Support ?
Hi everyone!
If you need help with your Snapmaker products or have questions before or after your purchase, we’ve made it easy to submit a ticket depending on your needs. Submitting a ticket is the recommended way to have your question or issue addressed properly and to receive detailed guidance.
  1. Pre-Sales / Order Questions
  1. Technical Support
  1. Track Your Ticket
  • After submitting, you will receive a confirmation email with your ticket number. Our team usually responds within 1-2 business days.
Snapmaker Orca slicing issue
RESOLVED: Snapmaker Orca and U1 ISSUE: Error 401: Unauthorized (See solution)
So I got the blob of death
Feeder squeak and disassembly warning
Snapmaker Android App
Terrible wall finish in one direction
Druckzeit U1 vs. P1S
X-axis movement exceeded travel limit
Multicolor Farbübergang Haftung in der Horizontalen
No sparse layers
How to disable camera turn off countdown in snorca? (and AGPL license violation)
Extruder nozzle grinding into prints
TPU - 95a - getting stuck in gears
filament pulling module
Tpu 自动进料
Snapmaker Orca 2.2.4 flatpak is not 2.2.4, crashes on fedora
PVB support
UI doesn't list wifi network
Stuck on print preprocessing
Fremdfilamente in Snapmaker Orca importieren
LAN-Modus und Snapmaker-App IOS
DOA. Can't get off the ground
Frequent pogo pin error
Zylinder Schale Mehrfarbendruck falsche Reihenfolge
Nozzle dragging on print
Print head is not "parked" correctly - solution
Spool detection hardly ever works
Snapmaker Orca and linux mint 22.2
Snapmaker U1 – Error 0003-0530-0002-0008 (Calibration Anomaly) after a hotend swap: how I fixed it
Failure to launch - Calibration/toolhead parking errors
Problems Printing Using 1 and 3 toolhead
U1 eror code
Filament stuck on the spool
Hotend Scraping on Build plate - Cause 4: Loose or Dislodged Hotend
U1 costing me time and money
NO CAMERA - Windows Snapmaker Orca or Android App
Snapmaker U1 - Issue with color matching
First layer offset for exposed infill
iPhone App
U1 - how overrule filament detection
U1 Homing Anomaly 0002-0528-0000-0011
New to Snapmaker Orca, Device Interface is... lacking, any help?
Incorrect replacement sent
Network unstable timeouts and connectivity issues - Android iOS and SnOrca
Snapmaker Orca Check for Updates Failing
Uneven layers
High-pitched noise when the printer moves laterally
Direct connection between pc and U1?
Network settings button
Donde encontrar esta pieza?
Please try again later
Snapdryer polymaker with 001 error message
Pressure Advance Calibration G-Code Error
Have any of you here experienced this
