TPU - 95a - getting stuck in gears
Just received my U1, bought it mainly for tpu. I tried slot 4 first, print got 1/2 way through and then started air printing, nothing coming out. I had to take apart the tool head to remove the TPU stuck in the gears
I then tried slot 3, that worked, the object printed. Last night I tried slot 1, same as slot 4, tpu not stuck in gears, I have not unassembled toolhead 1 yet.
My question is, is this the experience others are having? Anything I can do to improve the situation?
I have the spools in a cereal box with rollers, its a free 3d model on various sites. The tpu flows pretty easily out of the cereal box, meaning not much drag with the design. I place that box so the filament runs straight into the feeder slot
I’ve also experienced the same situation as you, but it was because I didn’t adjust the parameters properly and the print speed was too high. You can refer to the suggestions on this page to optimize your print parameters.
Filament Library | Snapmaker Wiki
Thanks,
I’ll try the settings and see if that resolves the issue, I’ll report back.
If you’ve not done so already, try bypassing the feeder motors . I bypassed the filament feeders on the side of the U1 when using TPU. I successfully printed models on the U1 yesterday using Bambu’s TPU 95A-HF, and with the generic TPU 95A-HF profile. I’ve not tried the non-HF so my scenario is slightly different from yours.
I manually fed the TPU into the extruder gears. There is an option when loading filament to choose manual vs automatic.
