Snapmaker 2.0 Firmware Updates and Downloads
Dec 13 2021: Snapmaker2_V1.14.1
Thank you for your suggestions on how to make the Snapmaker 2.0 better. Your feedback is always appreciated. Here comes the latest version of the Snapmaker 2.0 firmware.
Changelog
Module
New Features
  • Support 10W High Power Laser Module
  • Add minimum version requirements for each modules.
Controller
New Features
  • Refactor G-code transmission for Printing.
  • Support 10W High Power Laser Module.
  • Add “M76” G-code for triggering pause request in printing.
  • Add “M1012” G-code for Emergency Stop Button status output.
  • Prohibit machine moving while controller could not recognized machine model.
Bug Fixes
  • Fix a bug where home_offset could not overrode in some case.
  • Fix a bug where “M92” G-code could not saved parameters.
Improvement
  • Optimize printing time consuming in Laser Engraving.
  • Optimize “M92” G-code output in console.
  • Improve sstp protocol for Touchscreen.
  • Optimize config file read/write logic for safety recovery.
Touchscreen
New Features
Bug Fixes
  • Fix a bug where Wi-Fi status won’t updated when enabled/disabled Wi-Fi in Settings > Wi-Fi.
Improvement
  • Optimize 3D Printing Calibration
    • Touchscreen will pop up confirm dialog while machine was not calibrated successfully.
  • Improve touchscreen recovery from application crash.
  • Improve UX for unplug USB drive.
  • Update German and French copywriting.
  • Update resources for Settings > About Machine.
Downloads
Snapmaker2_V1.14.1
MD5: 2511404378127c07f2138838fa70a9df
Notes
This firmware update is only compatible with Snapmaker 2.0.
To see your current firmware version, go to Settings > About Machine .
How to Update Firmware
  • Via a USB flash drive
    • Put the firmware update file Snapmaker2_V{version}.bin in your USB flash drive.
    • Plug the drive into the Controller.
    • On the Touchscreen, tap Files > USB > Snapmaker2_V{version}.bin .
  • Via Wi-Fi
    • On the Touchscreen, tap Settings > Firmware Update .
    • Read the changelog and download the firmware.
    • After the firmware is downloaded, tap Update Now .
