Initial Calibration fail
Seems to be, that I solved it. It is possible to update the firmware to the new V1.14.1 version. For the F…version I just disconnected the printer module and turned the machine on and it was possible to access the menu to change the firmware which I first downloaded here:
Snapmaker 2.0 Firmware Updates and Downloads - #18 by Alan and following the instructions.
After 5 to 7 minutes the machine was updated, I turned it off and connected the printer module again and the callibration process started fine.
I hope that this helps you folks.
Enjoy
