While looking through the posts for printing flexible filament, I see there are many adapters to add to the print head. I purchased the one from Shapeways but the instructions for installing it do not match the print head on my S2. Is there an adapter for flex filament for the S2?
Thank you sdj544, I did try to print this part on my S2 earlier with PLA and it kept breaking apart when I tried removing it from the bed or cleaning out the support material. I also tried printing the 2 part file but couldn’t get the files to lay flat on the bed in Simplify3D. Don’t know if the orientation is off in the file.
I had the same trouble printing which is why I ended up doing the cnc version.
There are both a 2 part version and the single piece version. Some people have had better luck with one verses the other.
You might try glue stick or blue tape to help get it off the bed easier.
