A350 has ceased to function
I haven’t used my Snapmaker 2 in several months, I went out yesterday to set it up to do some laser burning and it seemed boot properly but when it went to home the laser nothing happened. I went to the control screen and tried to move the head/platform and nothing is responding. I went to one of the sub-screens and it says that no tool head is installed.
So, it’s obviously broken in some manner, is there a way to get some kind of diagnostic report that might help me figure out what in particular is broken?
If it’s sat for awhile, I would go over every single cable connection on the machine first. Some form of corrosion or oxidization might have happened so unplugging/replugging a few times might clean those up.
Grab the latest firmware, place it on the USB, and install it, just to make sure everything is on the same level. If it still doesn’t move, go into the settings > about machine and see if it reports the machine type properly. It does this by reading the linear module length.
As stated check all the cables first. Do the easy stuff to begin with, If it’s just been sitting it should not be something too drastic.
You can contact SM support ( support@snapmaker.com) and make a log file. https://wiki.snapmaker.com/en/Snapmaker_2/manual/export_logs
Here is also some sort of troubleshooting available:
https://wiki.snapmaker.com/en/Snapmaker_Luban/manual/2_supported_gcode_references
I unplugged and reconnected all the easily accessible cables, according to the screen I’ve got the latest & greatest firmware. When do the Settings > About Machine it reports that I have a SnapMaker Vulcan with a 0 x 0 x 0 work area.
Hi @StumbleRunner,
it’s really very strange :
:thinking:
In my opinion you should make a booting log which is very useful for diagnostics.
Connect Snapmaker to your computer with a USB cable and follow this guide : https://support.snapmaker.com/…/360055487434-How-to-Get…
You can show it here - then we can tell you more.
You said you have the latest firmware according to the screen… A while back there was a bugged FW that would not allow Wifi updates after it, so you had to update via USB, then go back to Wifi… Check you do actually have the latest FW versions.
Reseat and double check that X/Y/Z cables are in the proper place yet again (little extra contactor rub won’t hurt). It’s obviously not reading the linear rails. This could be a problem with either the linear modules, or the controller.
Download versions 1.13.2, 1.14.1 and 1.20.3 from the above link. Place all the .bin files on the USB drive, and ‘print’ them via the touchscreen like you would any project.
Run the 1.20.2 first and see if that fixes it. If not, run the 1.13.2, then check about machine, regardless of what it shows, run 1.14.1, then 1.20.3. That should ensure all firmware is up to date and matching. The Reason for the 1.13 is that’s before the module verification, then 1.14 adds that support in and updates the modules, then 1.20 is the latest. See if things come back online after that.
Just tried this on my laptop with a fresh install of Luban and the CH340 drivers. Rebooted and Luban doesn’t see the serial port at all, so just for grins and giggles I tried connecting via wi-fi, but it immediately disconnects, even before I get the chance to ‘allow’ the connection on the touchpad.
According to the “About Machine” screen, i have Snapmaker2_V1.20.3_20240716 installed
Export the logs and upload it here.
Okay, there are 2 different types of log files FW and SC. Even filtered down to just the stuff from the last time it worked and the first it didn’t and removing a bunch of duplicate lines, the two files end up being ~200 and ~1000 lines. Do I really want to upload them here in their entirety?
looks like i have a bit similar problem, wasnt using it for a realy long time, 2 years…
mine is bootin, but thats it.
No Wifi, cannot read the old files on the usb, laptop can, laptop finds the SM not if connected with usb, if i try to go in the setting, the screen on the machine gets grey and stays like that…
The original usb stick has 3 entrys,
Duo4.snaplzr
LOST:DIR
SYSTEM VOLUME INFORMATION
But cannot read the print or cut files…
On the board is only a Android file…
Whenever i click one and try to get to the settings, freeze…
Any ideas?
Thanks,
Wolfgang
I would start here and check the touchscreen connector and cable:
i have checked the cables, looks fine.
But looks more like there is no programm working.
Or no orders can be followed.
If i do a restart, it boots and is the same as before…
Do you have any spare parts like a toolheadcable?
Get any connection to a terminal over wifi or usb?
Did you already export your logs?
Okay, following the gcode reference i posted before you have following options for diagnostics:
M1005 (SM2.0) - Get Basic Info of Controller and Modules
Description
  • Get the basic information of the controller and modules, see the following example for details.
Marlin SM2-4.7.2
Compiled: Jun  3 2024, 17:42:45
PACKAGE: Snapmaker_V4.7.2
Module Ver:
Module 0x00C048D4: v1.14.6
Module 0x00C02468: v1.14.6
Module 0x0002C4DE: v1.14.3
Module 0x00C048D8: v1.14.6
Module 0x00C048E0: v1.14.6
Module 0x00C048F0: v1.14.6
linear_tmc X1 length: 356 mm, lead: 20 mm
linear_tmc Y1 length: 356 mm, lead: 20 mm
linear_tmc Z1 length: 356 mm, lead: 8 mm
linear_tmc Y2 length: 356 mm, lead: 20 mm
linear_tmc Z2 length: 356 mm, lead: 8 mm
kits: quick_change_kit
Machine Size: L
ok
M1006 (SM2.0) - Get Toolhead Details
Description
  • Get detailed information of the toolhead. For different toolheads, the information format may vary. Only key fields are explained here, and see the following example for details.
    • 3DP
Tool Head: 3DP
active_probe_sensor: 0
hotend_type: 0: 1, 1: 1
hotend_diameter: 0: 0.40, 1:0.40
Kp: 150.000, Ki: 1.000, Kd: 30000.000
z_compensation: 0: 0.585, 1: 0.397
echo:Hotend offsets: 0.00,0.00,0.000 26.00,0.00,-1.524
ok
* `Tool Head: 3DP`: Toolhead type - 3DP.
* `z_compensation: 0: 0.585, 1: 0.397`: Z probe compensation.
  • Laser
Tool Head: 20W LASER
Current Status: OFF
Current Power: 0.00
Focus Height: 65
ok
* `Tool Head: 20W LASER`: Toolhead type - 20W Laser.
* `Current Status: OFF`: Current status of the laser.
* `Current Power: 0.00`: Current power of the laser.
  • CNC
Tool Head: 200W CNC
rpm: 0, error: 0x0
M_I: 346, M_V: 24.23
M_TEMP: 25.80, PCB_TEMP: 26.90
ctr mode: CNC_CONSTANT_RPM_MODE
run status: STOP
cur_power: 0 target_power: 0
cur_rpm: 0 target_rpm: 0
last error: 0x0
ok
* `Tool Head: 200W CNC`: Toolhead type - 200W CNC.
* `cur_rpm: 0 target_rpm: 0`: Current rpm and target rpm.
long break, as i had a medical problem…
I can not get anything out of the 2.0…
So i ordered a new controller, today i installed it, and its the same…
Cables changed, rechecked, it shows nothing onboard, and cannot read usb…
It shows the lost. dir and the system info, but if i click it, freeze…
Thats not what i like…
Does the toolhead show up on the touchscreen?
I guess it’s not, this means your gcode would not show up because the “detected” toolhead is not the correct one.
Did you try to change to a new toolhead cable or other toolhead?
Sharing the logs would help also, maybe exporting works if you disconnect any toolhead.
Post up screen shots so we can see what you see.
