USB port stopped working
A350 in use since December. I’ve always used USB sticks to take jobs to the machine and never had a problem. Probably done it 100 times. Suddenly a few days ago, the machine stopped recognizing ANY USB stick. Literally ran a job, 10 minutes later tried to run another job, and the stick wasn’t recognized.
The Files app on the touchscreen has USB greyed out when a working FAT32 stick that previously worked is inserted.
Tried both USB sticks I regularly used (FAT32), tried the stick included with the SM. Tried a different USB stick. Followed the FAQ article to reformat a stick to ensure it was FAT32, still didn’t work.
Checked for firmware updates, and updated (was previously running the first version that added support for the rotary module). No luck.
Powered down the machine and let it sit a few days, no luck after powering back up.
I can send jobs over WIFI, so the machine is still usable, but I’m concerned about the loss of the only USB port on the machine. If the port is dead, removes the ability to use USB sticks, update firmware via USB, or direct connect to a computer.
Any suggestions?
Thanks! Just submitted a support request. Was hoping there was an easy common fix…we’ll see what support says!
i have the same problem since yesterday powered the machine down and left overnight it made no difference .
In my case I cannot use it as the machine is located outside of wifi so interested in any updates you might have
Same happened to me today … it worked fine yesterday and stopped working today. Were you able to fix it?
A350 - Printing via wifi works …
I have found that heavy use of a USB port eventually causes problems. Thus, I ported the machine’s USB to an external jack, figuring if I wore it out I could just replace the extension cable.
Thank you for this advice. Since my display stopped working completely today I think I’ve got a bigger problem …
:see_no_evil_monkey:
Or do you still have warranty?
One of first things i bought for my 2.0 were a USB 2.0 Extension to get the USB port better usable :wink:
Hi @Eisbaer
If the USB drive format has been confirmed correct, the issue is likely a faulty USB port on the controller board. Please refer to our troubleshooting guide here :backhand_index_pointing_right:
https://wiki.snapmaker.com/en/Snapmaker_2/troubleshooting/cannot_read_file
