Z-Axis Linear Module
I just received my snap maker with the enclosure and whenever I try to calibrate the heating bed, the z-axis linear module over extends and hits the front sliding door of the enclosure when it is closed.
How can I fix this problem? I am new to 3D printing :smiley:
Thanks
It sounds like its not assembled properly. The linear modules should fit in the grooves in the base completely, and should not overhang the front.
This happens so often…
