Thank you for the add.
I have the A250 since last Oct and has been using Laser module & 3D printer head so far. It has been working well until recently (after upgrade to 1.11.4). I’ve found that the Z-axis doesn’t work evenly during the bed-level calibration process. The left side always start moving earlier so the X-axis is not lifted evenly as you can see in the first clip.
Then after the final calibration step after press “save”, the Z-axis seems to stuck after moving up just a bit. This happened every time at the calibration. It’ll print almost normal (have some issue with first layer) afterward but this symptom (as in the second clip) give me a fear that it’ll fail soon.
I tried switching the cable between the two linear modules but result is the same. So it’s not a connection or cable issue.
Please kindly advice.
Cheers…Som
