You can print one in a pinch - Printables
It probably took longer to type all that then it would have to check the wiki - Quick Start Guide for 2.0 Quick Swap Kit | Snapmaker Wiki
@Padre-O Could you please show me whatâs the instruction card that you have found in the Quick Swap Kit package? As I know, it should guide you to go to Snapmaker Support Center to read the Quick Start Guide instead of watch a video. Thereâs no video tutorial for Quick Swap Kit, but an online Wiki and a PDF version. Iâd like to know what cause the misunderstanding. Thanks.
@profhenning @Wyphorn Yes. You can buy the toolhead plate separately. Get it in the Accessories for Snapmaker 2.0 category in the store:
In the Quick Start Manual thereâs a remark that confuses me:
@Jade would you mind to explain what is the difference?
Hi, Riskey and @Jade.
I think it is necessary to mention the work area when using the dual extruder.
This is easy to explain. They saved money and did not filled all of these adapter screws I highlighted in my picture.
I Had the old frame which was quiet wobbling as this is one of the first devices of Kickstarter campaign. So i wanted the new frame for printing and just switched all screws from old to new frame. So the wobble one is now for CNC where it is not that hard when I have ±0.5mm.
And for sure. It is a weak from snapmaker that they donât Install these 8 screws from factory. This is 1$ extra. And now they have to wrote that note in the document and all think"wtf?". I cant understand that.
That was/is my plan also! Is the new frame at least flat (enough)? My anxiety was that they used frames that did not pass QC hereâŠ
Yes! Exactly my thoughts! I mean, for what it is the Quick Swap Kit is not really cheap⊠The few screws really would not have hurt
Thanks for sharing your information! Will do the same as you and swap screwsâŠ
Was a little disappointed that those M6 hex head with M4 thru hole bolts werenât installed. Wanted to use the new frame for FDM and the old frame for CNC. I suppose I could just take the bolts from the old frame and pop them in the new.
Question for laser users. I have installed the quick swap kit and now the auto function for the 10w laser wonât work. Not a big deal since I am used to setting the laser and CNC manually. I was just curious if anyone else has had this issue?
Same here, auto height no longer works on the laser. Thought it was a coincidence, but apparently not. So doing manual now. I bet is something they can fix in the firmware.
@Dazwoodturner , @sciss - go to settings and recalibrate the auto height. It will start working.
Please fill out the Support Ticket Form
So they can get some feedback and fix this, it should message about this on the touch screen.
I will try that. Thanks!
