How to distinguish the original support platform from the new one? - Quick-swap
I have the 250 model and forgot which support plattform is from the original set and which is the new one from the quick-swap extension. How can I distinguish them? The instruction manual says that there should be a difference:
The original support platform that came with the machine should be used with the 3D
printing function.
The new support platform is only compatible with the CNC function, as it is not
compatible with 3D printing function.
I think you should see a difference in the screw holes.
Here is a platform picture:
Thanks for the quick response. Sadly, I still can’t find a difference and I don’t understand why only one of those should be used for 3D-printing and lasering. Is it because of the heat?
When both are same, then just use it as you want.
On the A350 the cnc platform had less nut inserts than the print platform.
If you want to use the new platform with all inserts, it is possible to move the inserts from the old to the new platform.
