Support Center, Firmware, Software & App Updates
Hi U1 Community,
We are happy to share that the Snapmaker Support Center has been updated. For users who have already received your U1, it is a convenient place to access the latest resources. For those who are still waiting, you can explore the information in advance.
The U1 Support page includes:
  • Software and firmware for download
  • Snapmaker App for iOS and Android
  • Wiki resources including FAQ, manuals, maintenance, troubleshooting, and replacement guides
  • Video tutorials to help you get started, calibrate, and troubleshoot
Firmware V0.9.0 Release Notes: Link
Snapmaker Orca V2.1.1: Link
Snapmaker App V2.1.0: Link
We hope this helps you enjoy your U1 and makes it easier to find the information you need.
Please click the link below to download the latest version:
Snapmaker APP :
I’m currently without an active Internet connection. Can I download the firmware update at work and install it locally from USB or SD?
Of course you can.
U1 Firmware Release Notes | Snapmaker Wiki
U1 Firmware Update Procedure | Snapmaker Wiki
Thanks, I saw the FAQ after posting… :sign_of_the_horns::sign_of_the_horns:
Update(2025.12.31)
Not sure if this should be a new post, or just a reply in this Support Center. Let me know.
I notice on the Snapmaker Github site there is a zip file called ‘orca_custom_preset_tests.zip’. If I download this and look at it, I see a HUGE selection of json files for all the filament brands I use (and more). Can I just add these to my Snapmaker Orca 2.1.1?
I notice the file has ‘….tests’ in the name. So, are these not validated for the U1 yet?
I would really love to take advantage of this extensive list of filament profiles, but don’t want to 'jump the gun’.
Thanks
Annoying that the U1 screen has Polymaker listed but when selecting in SnOrca you need to use a Generic profile… Is this part of the “tests JSON” and after testing is complete we’ll see those in SnOrca?
Update of Snapmaker APP:
Snapmaker App V2.2.2 , Wiki is here:
(EN)V2.2.2 | Snapmaker Wiki
(CN)V2.2.2 | Snapmaker Wiki
Note: HarmonyOS is still being adapted and is expected to be released in the next version, so this upgrade does not involve Huawei models.
Update of Snapmaker U1 Firmware – V1.1.0
A small firmware update for Snapmaker U1 (V1.1.0) is now available.
Note: This version is released ahead of the planned mid-February update. A new firmware version with additional updates is scheduled for mid-February.
For full details, please refer to the Wiki:
https://wiki.snapmaker.com/en/snapmaker_u1/firmware/release_notes/v110
New Features
  • Added selective flow calibration. Users can choose specific toolhead(s) to perform flow calibration, avoiding redundant calibration on already calibrated toolheads to reduce preparation time.
  • Added QR code guidance to certain error message pages. Users can scan the QR code to access the official solution for the corresponding issue, enabling faster troubleshooting.
  • Added support for additional official RFID filament types.
Improvements
  • Optimized cooling fan control logic to reduce fan noise from idle toolhead(s) during printing.
  • Improved the AI defect detection model to reduce false positives.
  • Optimized print time calculation logic. The duration shown on the print completion page now reflects the actual printing time, excluding paused time.
  • Adjusted Z-axis motor current parameters to increase Z-axis output torque, improving print quality issues caused by insufficient torque.
  • Added a medium sensitivity option to the filament tangle detection feature.
  • Optimized the UI display for storage space management.
  • Auto-Refill is enabled by default after updating the firmware.
Bug Fixes
  • Fixed an issue where the firmware could shut down if the start G-code did not include a layer count command.
  • Fixed an issue where the nozzle temperature could be modified unexpectedly during pre-extrusion.
Update of Snapmaker Orca V2.2.3 (Beta)
changelog is out—links below:
Update of Snapmaker U1 Firmware – V1.1.1
CN:V1.1.1 | Snapmaker Wiki
EN:V1.1.1 | Snapmaker Wiki
Update of Snapmaker Orca V2.2.4
CN:V2.2.4 | Snapmaker Wiki
EN:V2.2.4 | Snapmaker Wiki
Snapmaker App V2.2.3
This is the second firmware update in a row where my U1 with the hardened 0.4mm nozzles installed has repeatedly failed to complete the bed leveling calibration after the update, error code 0003-0530-0002-0008. In both cases, doing a factory reset and going through the entire first-time setup process again resolved the problem and got the printer working again. I’m not 100% sure this is caused by the updates, it could just be a 2x coincidence and there’s some other issue causing this. Is anyone else having problems with bed leveling after applying firmware updates?
Bed leveling worked for me without any problems.
Thanks, I must have something else going on. Guess I’ll be doing some printer troubleshooting in the morning!
I’ve had my hardened nozzles for a few weeks now… Guess I need to get them installed! I’ll post if I have any issues​:sign_of_the_horns::sign_of_the_horns:
Update after further testing:
The issue appears to have been caused by the hardened hot-end installed in tool 1. Removing it and reinstalling the stock hot-end got me 3 consecutive successful bed level runs. With the hardened hot-end removed, I could see a small but apparently significant scratch in the copper plate on that hot end, so I swapped it for the one in tool 2. Again, 3 consecutive successful bed level runs.
I did open a ticket for this, but unless I hear differently from support I’m going with this scratch being the root cause of my issue.
