the table floating so much that in that same area the spindle stop spinning…
i tried a 1MM step down… spindle stall
i tried 0.5MM spindle stall…
on this video there is a 0.2MM step down… spindle stall
that is raises many red flags
1; the advertisement of snapmaker said machine cable of cutting up to 15MM deep… that last cut was 0.2mm
2; spindle has no power… at all
pause/halt wont stopped the movement until the last started line finish (single block movement)… so so dangerous, especially when the spindle in stall… not only the work piece or the cutting bit (tool), but a spindle it self getting damaged like that… pause mean stop every movement right on that second
i dont want to buy a e switch, which should be part of the machine, but all it does its cuts the power… that i can do on my own… just pull the plug… all this are very disappointing…
as i show, i program, set up cnc mills, wire edms, over 30years… some time ago laser and waterjets, also
but in the last 5years only edm’s and mills only
so im sure i have an idea how this should work…
and that isn’t…
question… if i mill (here at work) or 3d print some sort of sliders (support) under the table (under the carriage… (meaning the web thing with nuts, what we screw the waste board on, on not the 2 post, which come out of the lead screw)… will your machine able to handle power wise… obviously the spindle has no power, at least nowhere near to what ben advertised… but a machine would able to handle some sliding support, rail system? or i just would waste my time even more?
and i have no idea what to do with a spindle being so weak… my battery operated dremel, which i dint charged for a while, dig in to this soft wood, and was able to carve steadier , then the snapmaker spindle
that is disappointing
especially that a 3d printer and laser works just fine… the cnc i get around it for now… if i have to i just bring the material to work and do it on this cnc’s
