My object is not centered on print bed. How do I move object to center of print bed?
thanks for help
thanks for help
For more help you will need to post info about your setup and settings, it might be as simple as clicking a button. In S3D there is center and arrange button, in Luban you can right click the model and select center selected model.
The center of the bed is dependent on the size of the unit, for A350 it’s X=160, Y=170. If you are in the workspace in Luban your model will be in the upper right hand quadrant on the axis, the center (0,0) is the left front of your bed facing the unit straight on.
