In the workspace it shows it in the top right quadrant as you have described. I believe that as long as the part you are printing is centered in the quadrant of the workspace you are fine to print.
Hello,
you just have to go to the bottom left corner of your build plate. On the X0 Y0 . Then you set the working origin for x and y. After that you can start the print and everything will be centered.
Hello,
sorry I didn’t express myself correctly.
If you want to print via Luban, press “Go to work origin” on the bottom right. If it is not where you would like it to be, you must use the x + - and y + - buttons on the bottom right to move to your desired position. Then press Set work origin. Then start in Luban. The Snappmaker usually remembers the last work origin.
