I have recently recieved the A250 after the Kickstarter project. Assembly and set up went perfectly but I’m having trouble when it comes to using Luban.
I have installed the latest version from the Snapmaker site, connection to my machine over Wi-Fi is fine but whenever i try to load a model in to Luban to get it ready to 3D print, the screen goes completely blank. All I’m left with is the ‘File’, ‘View’ and ‘Window’ tabs at the top. The best i can do is select reload or force reload which just restarts the software. The software hasn’t crashed and still responds.
Does anyone have any ideas what could be causing this or how to get it to work properly?
Just a few points to mention;
I have tried uninstalling and installing the software.
I have updated my machine to the latest firmware version listed on the Snapmaker site.
I have tried Wi-Fi and Serial Port connections and end up with the same result.
I can use Cura to save a model on to a USB stick which then loads directly in to the machine and prints perfectly.
I haven’t tried laser cutting or CNC carving functions with it yet.
Any assistance would be appreciated.
