Luban splits lines
Hello,
I am making cutouts with the laser. As I scale the simple line drawing in vector mode, the software is splitting the lines in the drawing. I have made the lines 3 pixels wide in a 1200x1200 drawing and as large as 10 pixels wide. Still the same. The same drawing previoius version was fine and the tool path generation worked with only one line, but there were a couple of areas I needed to fix. These fixes were not visible in the render, nor in the toolpath, but the equipment made these cuts Phantom cuts perhaps. Picture here
So
  1. How do I keep luban from splitting lines in drawings causing the laser to follow toolpath twice about 1mm apart
  2. How do I keep the system from making phantom cuts, that arent in the drawing, nor in the toolpath?
Thanks
D
Did you try cut on path? I am no frequent user for laser and luban, pls apologize if it’s no useful hint…
Anyway, if you want to upgrade, there are a lot people using lightburn.
