Hello.I am brand new to the forum so apologies if this question is already answered by my issues is this.
When trying to import any sort of large image after I process it from the imported file snapmaker luban will automatically splint any outline into two lines with a white space in the middle I assume if the line is above a certain thickness. This means that when I go to cut the Snapmaker will make two, slightly off passes over the same areas and take twice as long to cut. Is there a way in snapmaker Luban to change this or do I have to figure out how to import thinner lines? Is there a specific file time that will automatically create only a single line for cutting? Im brand new to laser cutting/engraving so any help would be appreciated. Thanks in advance!
FYI: I have already tried decreasing the black to white ratio to the lowest it will go and still maintain a solid line and while this does bring the two lines close enough that the cutting is more efficient there are definitely still double passes occuring. Thanks!
