Hi I have the special request,…
How can I reverse the direction of the laser engraving so that the lines are executed in the X axis and not in the Y axis, the Y axis makes much more noise than the X axis, so I would like to change that.
It is possible?
If you use Lightburn instead of luban, you can rotate the scan angle direction (scan is the term for the laser going back and forth over the object.)
I am unsure how to do it in Luban
How much more noise is your Y axis making? There have been some complaints of defective linear modules. If it’s loud enough, support will replace it.
