J1 Community FAQs
Contents
#1
  1. Does it necessarily replace a whole hot end if I clog up a nozzle?
  2. Print heads are sold in pairs with the same nozzle diameter. Can a different diameter nozzle be fitted or can I mix and match print heads?
  3. Will you provide Cura/PrusaSlicer profiles?
  4. Will there be an update to allow you to change nozzle size without buying an entire new pair of hot ends?
  5. When will the pre-order discount end?
  6. When is the built-in-camera option coming?
  7. What about changing filament mid print? Does it support the M600 and M0 gcode commands?
  8. Dimension accuracy: How to tighten X, Y axis belt?
  9. What is the difference between the left and right hotends or are they identical/reconfigurable to be used both sides?
  10. What are my options for printing? Is there any kind of octoprint-like web server I can send jobs to via WiFi?
#2
  1. Is there a protection procedure in case the z leveling fails? (What happens if the nozzle does not recognize the bed / bad contact between them?)
  2. Will you offer some PEI spring sheets instead of glass beds?
  3. Given the silicone pad, WHY and WHEN is purge tower necessary for multi-colour print?
  4. What decision was made about a cheap exhaust option (not in accessories atm)? If DIY, what suggestions do you have?
  5. Why does J1 need a wipe tower?
  6. Is it possible to integrate it with a tool changer system like printer mods’ exchange?
  7. In dual extrusion, can different size nozzles be used?
  8. Is there a preventive maintenance plan like greasing the linear guides every 1000 hours of printing? (just a example)
  9. When will an internal camera become available?
  10. How and when can I get the shipping numbers?
#1
Polls: 2022-11-11 to 2022-11-14
Votes: 304
Answer Date: 2022-11-17
No. 1 - 19%
It’s not necessary to replace the whole hot end when you encounter a clogging issue.
A large majority of clogs can be fixed without the need of replacing hot ends or nozzles. First, you can open the latch on the front of the print head to check the filament loading status since it will release the tension of the driven gear, allowing free filament movement and better access and visibility to the mechanics of the direct drive system. For example, if the clog happens in the hotend, you can heat the nozzle to about 250°C and use the provided H2.0 Allen key to push the filament through the clogging area. If the clog happens in the extruder, you can use a tool (eg. tweezers) to remove the filament that’s stuck in gear. If the clog happens in the nozzle, you can heat the nozzle to about 220°C (for PLA), and use a nozzle cleaning tool or a metal string with a diameter that is smaller than the nozzle diameter (0.4mm) to push the clogged material backwards through the nozzle tip. Do this step with high-temp. protective gloves.
If the hot end has been used for a long time or has been damaged, you will need to replace it. J1 uses easy swap hot ends. You only need to loosen two screws to replace the hot end. Also, J1 can automatically recognize the hot end type with the PCB connected with the hot end. Please note that the left and right hot ends are mirrored. So they cannot be used interchangeably.
J1 supports standard MK7/MK8 nozzles. If you don’t want to replace the whole hot end and you are sure that you can handle the nozzle replacement after reading our guide (Similar to normal nozzle replacement on most 3D printers. I will share a video to show the process soon.), you can replace the nozzle instead of hot end. It will require some tools to make it. Also, J1 won’t be able to automatically recognize the nozzle type if you have changed that. BTW. The heat sinks, heater blocks, heat breaks, fans, and nozzles are identical on both extruders.
No. 2 - 16%
In progress. We need a little bit more time to find a better solution. I will follow up the progress on this and share the latest update later this week.
No. 3 - 14%
Will you provide Cura /PrusaSlicer profiles?
Yes. We have released J1 Cura Plugin. You can find it on our forum and github. The plugin provides J1 machine configurations and various materials printing profiles. GitHub - Snapmaker/SnapmakerCuraPlugin: Snapmaker plugin for Cura 5
We will release printing profiles for PrusaSlicer at the end of Nov. 2022. Currently, there’s only PLA profiles sharing on our forum. Beta Version - High Speed Firmware, Cura Profiles, PrusaSlicer Profiles
In addition, we will provide profiles for ideaMaker and Simplify3D after we release profiles for PrusaSlicer.
No. 4 - 10%
J1 can recognize nozzle diameters when they connect with the machine. However, current J1 firmware doesn’t support manually changing nozzle diameters.
This feature is in J1 firmware development plan. Users will be able to turn off auto nozzle recognition, and then manually enter the nozzle diameter value on the screen.
No. 5 - 7%
As J1 production runs to the next phase, the preorder price will be increased gradually during preorder campaign. Early adopters enjoy bigger discount. In the next phase, it will be increased about $50. Snapmaker J1 newsletter subscribers will receive email notifications about the pre-order price update a few days before it changes in the store.
No. 6 - 6%
There’s no built-in-camera addon plan. Back to the early days of J1 project, we considered adding the camera module to J1 in the future. However, in the past year development, we mostly enhanced the machine reliability, printing speed and quality, while the camera is a lower priority. In the latest product improvement plan, we are not going to make the camera module. Although we won’t release camera module, advanced users can connect J1 with a Raspberry Pi running Octoprint to realize remote control for J1 if needed.
No.7 - 5%
Currently, it doesn’t support these commands. If you need to change filament mid print, you will need to pause the print and change the filament manually on the screen.
No.8 - 4%
If belts are too tight, it will affect printing accuracy. If belts are too loose, it will cause step-missing problems. So we need to adjust belts to a suitable tightness.
We will provide belt adjustment method in J1 user manual, which will be released at the end of Nov. 2022. To put it simply, users can easily adjust X, Y axis belts using a 3D printed adjuster. We will provide the G-code file of this adjuster in the manual.
No.9 - 3%
The left and right hotends use mirrored design. They cannot be configured to be used on both sides. The heat sinks, heater blocks, heat breaks, fans, and nozzles are identical on both sides.
No.10 - 3%
What are my options for printing? Is there any kind of octoprint -like web server I can send jobs to via WiFi?
Yes. You can send jobs to J1 via WiFi in Luban (Snapmaker slicer for J1), Cura (with provided J1 Cura Plugin), or via USB flash drive.
#2
Polls: 2022-11-19 to 2022-11-23
Votes: 205
Answer Date: 2022-11-27
No. 1 - 23%
There’s stall protection for the calibration procedure. J1 uses TMC2209 motor driver IC, which comes with StallGuard feature. We use it to verify whether mechanics function within the safety margins, avoiding crashing into the heated bed or the glass plate. (Learn more about StallGuard feature on Trinamic website: https://www.trinamic.com/technology/motor-control-technology/stallguard-and-coolstep/)
The bad contact between the nozzle and heated bed can be identified with StallGuard feature. The bed will stop rising, and the J1 touchscreen will alert you that there’s an error. (Here’s a short video I took before. You can learn how protection takes effect from the video. The screen UI is in Chinese. I’ll take an English version next time.)
Update Starting from firmware version V2.2.10.
  • Fixed stall protection failing risks occur when there’s a glass build plate on the heated bed.
  • Added stall protection for Z homing.
Possible risk (for current firmware version) - The stall protection fails during calibration when users forget to remove the glass build plate (in the case that users ignore the screen’s warning of removing the glass build plate). Reason for this issue: We found that there are differences in each TMC2209 motor driver IC for their StallGuard performance. Especially, when adding the glass plate (that makes the platform becomes heavier), the probability of failure increases a lot. We cannot set optimal sensitivity settings for this feature. To avoid annoying false error reporting and process blocking, the current settings will cause a risk of stall protection fail when the glass plate is on the bed.
No. 2 - 21%
No. The PEI spring sheet (flexible buildplate) is not supported. J1’s dual extruders move on the same X axis. It’s virtually impossible to use mesh bed compensation for IDEX 3D printers. So it’s super important to choose a reliably flat build plate. In J1, we use glass build plate instead of the flexible spring sheet. Glass is naturally stiff and thermally stable. Therefore, it remains flat and will ensure bed leveling remains consistent. The metal flexible plate is not comparable.
No. 3 - 12%
When printing at a low temperature, like 195℃ for PLA and a low printing speed, like 40-60mm/s, the prime tower might be not necessary for an IDEX 3D printer. However, J1 prints at high speed (≥ 200mm/s), it requires to increase the nozzle temperature to above 210℃ to increase material flowability. The material easily oozes because of gravity and flowability. So we generally enable prime tower feature to get better print results for dual-color printing: save printing time with high-speed printing, cleaner print surface, and accept a small amount of waste of material.
No. 4 - 8%
This is still in internal discussion. We have put print cooling improvement as a higher priority than air filter feature. The latter will be influenced by the former. I hope that I can share more after we complete tests on this. Before that, there’s no progress.
No. 5 - 8%
It’s the same answer as the one for No. 3 above.
No. 6 - 6%
No.
No. 7 - 6%
Yes. You can use the same size of nozzles or different sizes of nozzles in one print.
No. 8 - 5%
Yes. There’s a maintenance plan for J1. You can read this content in the J1 user manual. Download here: https://support.snapmaker.com/hc/en-us/sections/10129930251671-Snapmaker-J1
No. 9 - 4%
It’s not in the plan. It’s a same question as FAQ#1 No. 6 - 6% - When is the built-in-camera option coming? Please check out the answer under that question.
No. 10 - 3%
For Kickstarter rewards delivery, please read this topic: J1 Kickstarter Rewards Delivery Info
For Pre-order delivery, please read this FAQ: https://support.snapmaker.com/hc/en-us/articles/10430772962455-Pre-order-Shipping-FAQ
As an Early Bird to a250 reading the above answers i came to conclusion to never consider Snapmaker again. Ever.
So you are actually pulling off the same software chaos. Using probably a build of marlin without M600 support.
Nozzle detection, we are working on it. Do you still believe your own words? With your normal working speed on the firmware side, you get a working version in a year. But hey, until then the Snapmaker J2 is probably released.
I am so fed up with you guys.
Wow. Sounds like you had quite the experience. Just for reference, the J1 has been printing fabulously straight outta the box. I was actually looking for MORE snapmaker stuff because I’ve been so impressed by the J1. Your comment has given me pause though.
I downloaded and installed Luban, but I’m not seeing the J1 as an option. Is this just the usual issue where Mac support lags behind, or am I missing something?
J1 support in luban should appear in version 4.5.0 as earlier mentionned by Jade. This release announced for november has been delayed , probably due to difficulties even in current 4.4.0 version. Snapmaker did not communicate on a 4.5.0 release date.
The A250 profile is working surprisingly well so far?
I’m printing a toaster, sliced in Luban with the A250 profile. On the first try, I discovered that I needed an offset for the build volume. I rotated it 90 degrees and moved it 50mm towards the front. I even added a brim, and it still fit. I’ve never printed before, but I get a sense that maybe the scale is off slightly. I think maybe it’s bigger than it should be? Anyways, it’s at 11% now and 95% work speed since I haven’t been having much luck printing anything. We’ll see where it is in the morning.
Actually I didn’t get that information before.
Would have been clever by Snapmaker to communicate this before everyone askes the same question to the support :wink:
Jade mentioned that Luban should have been ready a couple of Friday’s ago.
Luban v4.5 beta 8 has been released now. Come and download! :smile: @naPS @Haselauer @Fanuel @rollermonkey
Any idea when the profile for Simplify3D will be available? I cannot get a decent print when slicing with Luban and printing ASA.
Not yet, but there are already Prusaslicer profiles for J1. You could have a try.
Call me crazy, but I just setup my J1 and cannot for the life of me find the directory on my local drive to install the Cura plug-in. I installed a fresh version of Cura version 5.2.1 on my desktop and when I go to the help menu to select ‘Show Configuration Folder’, nothing happens. I have searched my hard drive high and low for a Cura folder with a sub-folder for plug-ins and have come up empty.
On another note, I also installed the beta version of Luban for the J1 and the first print was printing about 2" above the bed. I did perform the out of the box configuration and test print and everything went fine.
Hi mmelchert830, did your J1 print above 2" above the bed throughout the whole printing process or at the beginning? It might lower to the appropriate Z height when it starts printing later. What’s your firmware version BTW?
I found in another forum discussion where another user had the same issue, I guess the cause was the firmware update. Once I re-calibrated the printer it began printing normal again.
I will keep in mind to re-calibrate after each firmware update.
Once I finish this mask project I’m doing for my daughter (in Prusa) I’ll give Luban another whirl.
I’m way too far along in this to change slicers mid-stream! :smiley:
Given #1.7, the J1 does not support M600, users should pause the print.
The J1 does not appear to support M25, or even M0. How can I pause the print at layer X?
The touch screen does not even show the current layer number, am I supposed to watch it and count?
I am quite concerned that the software for the J1 will be just as bad as for the A350. Not supporting something as basic as ‘pause at layer X’ is terrible.
