still trying to work this all out i need to do basic lettering without all the vector passes. got fusion on one months trial there are a few type faces in it that are single line, made a G code, has to use USB to get it to the snapmaker, not sure if it can be sent direct. however the G code tried to push the cutting tip thorugh the bed. setting looked OK origin set fine, aded the tip messurements in to fusion i was using still can not find out why. any one got idea,s
