Dual extruder bed leveling gcodes missing
I recently bought a dual extruder for the sm2 and had quite some bed leveling issues. Therefore I used the great Klicky probe guides in the forum + the models on printables for the dual extruder. Now that that was working It was way better but still not great with a 6x6 mesh. Wanted to do a 11x11 then but found out that the gcodes for leveling are not available for the dual extruder.
It would be really great to have 11x11 bed leveling without the automatic z offset on the nozzles at the end would be great to Save some pinched fingers.
@Jade I do know you have loads of stuff on the plate with the u1 coming. And i am in the first batch of Kickstarters there as well, but it would be still really great to get some updates/informations for the s2.0 as well (want to utilize the bigger build volume)
Here is how to do a leveling with a greater matrix:
But honestly I’m not sure how to proceed with the nozzle offsets, but it seems you know the way to go.
Some additional info:
Hello fellow Austrian :slight_smile: thanks for the fast response.
The g1029 command seems to only work for the single extruder. And It seems that there are no commands for the dual extruder publicly available.
It seems that at the moment bed leveling with the dual extruder is only possible via the macro on the screen.
To complete the information, here is the reference for G1029:
https://snapmaker.github.io/Documentation/gcode/G1029-abl
Welcome from Linz :wink:
In theory this should be an easy fix to the firmware.
I have to retry with a fresh GitHub clone if you are willing to use a custom firmware from a stranger..
My recent changes made it impossible to run on a stock machine..
More reference:
And, sorry for the confusion, it’s a older topic :wink:
I think I read somewhere, that the bed isn’t stable enough in the corners to calibrate with the nozzle directly touching. That’s the way the do it on the artisan. Therefore they only do the z offset calibration in the middle of the bed with the nozzles, the rest with the sensor. As I use a Klicky probe I would need the z offset in the end anyways.
So you would make the g1029 work correctly? I mean in my opinion it is something that snapmaker should actually bake into the firmware themselves. As the sell the dual extruder explicitly for the sm2 as well and I think it is fair to assume that the same capabilities are available for the upgraded part as well.
Off topic: Just installed the bracing Kit and thought it would take me an hour or so. Actually took me quite a bit longer :sweat_smile:
Greetings from nearby Vienna :wink:
Not sure if I am able to implement this. If it’s easy enough I guess it would be possible.
I will report back..
No success till now, I asked the Devs about but I’m not sure if there will come anything back :smirking_face:.
I think it would make sense if they implemented the 11x11 in the gui as well. This way the user can just choose whatever fits best without having to mess with gcode commands.
It would also be nice if they gave us the option for a pause between leveling and z offset calibration then we could safely remove our clicky probes.
The gcodes used by the Android remote are M3002 and M3003, but one needs to run multiple commands in series to achieve full leveling.
; Test right extruder height
M3002 L0
; Test left extruder height
M3002 L1
; Auto level start 3x3 grid
M3003 L0 G3
; Test grid point 1 with inductance probe
M3003 L1 P1
; Test grid point 2
M3003 L1 P2
; Test grid point 9 (depending on size you need to generate P1 … P
M3003 L1 P9
; Finish leveling, this performs height test with force sensor and applies mesh
M3003 L2
Thank you for sharing!
This is the final script that I’m now using in Octoprint. The bed is supposed to be pre-heated (or also the chamber if there is a heating).
It is supposed to work with both: the normal mono print head and the dual version, this is decided based on the Octo print profile.
The mono code contains a machine dependent constant (the step with the calib card). You need to write down the number in the manual calibration.
For the dual head it is important to note the the hotend must be clean and COLD .
I created holes in the sticker surface of the bed with a 250° nozzle.
I found some info in the sources for the other 300X commands:
M3000 shows current settings relevant to the dual head (offsets, nozzle dias, …)
M3001 does a single probe run at current position, but has no effect on the calibration
M3002 should be used to find out the z-offsets of the 2 nozzles in auto mode, with Levels 2-5 also with the card manually
M3003 does the calibration automatically
M3004 does the calibration with manual interaction
M3005 does a single automatic probe to some center point, but does not change settings
; Home
G28
{% if printer_profile.extruder.count == 1 %}
  ; Grid level off
  M420 S0
  ; 5 x 5 Grid
  G1029 P5
  ; Execute Auto Level
  G1029 A
  G91 ; Relative Coords movement
  ; My Value! dont copy blindly
  G1 Z-2.0 F30 ; Move nozzle blindly to surface
  G1029 S ; Save Grid Level result
  ;G1029 D1
  G90 ; absolute coords
{% else %}
  ; Set the hotend temp to something low and
  ; non-bed-melting. Got holes with 250°C
  M109 T0 S70
  {% set grid_count = 5 %}
  ; Start leveling procedure - L0
  M3003 L0 G{{ grid_count }}
  {% set grid_points = range(1,grid_count*grid_count+1) %}
  {% for point in grid_points %}
    ;M118 Point {{ point }}
    ; Leveling step - L1
    M3003 L1 P{{ point }}
  {% endfor %}
  ; Finish and store - L2
  M3003 L2
  ; Make sure, leveling is on
  M420 S1
{% endif %}
how you run this script? G1029 A command do not work
You have to run each command one by one by entering it into a terminal:
thank you
Based off some of the comments here, and my (and claude’s) research and months of frustration with levelling and wasted prints I built
its a octoprint plugin that does bed 11x11 bed levelling with nozzle touches, also combines setting z-offset of both nozzles
in a similar vein for the xy nozzle offset built GitHub - chrisns/OctoPrint-NozzleAlign: OctoPrint plugin: measures the XY offset between two nozzles with a camera on the bed, and writes it to the firmware · GitHub
now all my prints are getting beautifully glossy flat bottoms and perfect dual-extruder alignments, all automagically
may be biased to my a350 dual extruder with quick-swap & bracing kit,
