I was able to successfully calibrate the camera, and capture images in Luban. I came back today and when trying to capture, the Start button does nothing, and the boxes at the bottom of the screen are grayed out. Unsure how top troubleshoot and did not find anything obviously related when searching the forum. Ideas?
After a series of powering it on and off and restarting Luban, I was able to get a capture, but the buttons at the bottom are still grayed out.
I’ve had some hits and misses before with the camera capture, it would finish all 9 pictures. I moved an access point of wifi alot closer for a stronger signal and it now works alot better.
It seems like the laser head has a seperate wifi connection.
Yes, somebody already dismantled the laser module and discovered that they’re using an ESP32-CAM board for the camera inside which is using it’s on board WiFi for the camera feed.
Wow that’s interesting. I’ll try some WiFi tweaks.
