Brand New to 3D Printing - 37 hour printing time normal?
Hi, I appreciate you taking the time to look at this.
As I said in the subject, I’m brand new to this, so please excuse my ignorance - and please also point me in the right direction if you’d rather not answer.
I received my Snapmaker 2.0 yesterday, got it all set up and started the first demo print as instructed in the manual. I have two questions.
  1. With the default settings that the manual instructed me to select it’s saying the vase will take 37 hours to print; is this accurate? Is this what I should normally expect in terms of print times?
  2. I noticed that in the adjust settings menu I can raise the printing speed to 500%! (This thing goes to 11!!) I’m expecting there is some quality loss with this, yes? What speed settings do you all recommend?
Thanks again for reading! Looking forward to being a part of the community!
Hey @demoniousrex, welcome!
For the vase, there is a quality profile for it, its called “caselibrary.vase.AXXX.quality”.
For future questions it would be nice to have a gcode+stl, maybe also a picture (the 3d object you want to print), so please upload it.
In this special case, you want to print a vase.- There is a preference under “Surface”, this is called “Spiralize Outer Contour” see the screenshot:
The print with this profile needs about 4hours.
Generally i would say, its a lot of trail and error learning 3d printing.
My favourite settings are:
  • layer height of 0.2mm (looks nice enough for my most prints)
  • initial layer width 120% (to get better adhesion)
  • initial layer speed 8-12mm/s (cause of adhesion problems of my unflat bed)
  • layer speed about 40mm/s (depending on the wanted quality)
  • wall thickness 1,2mm (depending on the model)
  • top bottom thickness 1,2mm (same)
Here is a useful thread which may also helps you in the future:
Hope this helps!
Feel free to ask again :wink:
You sir are awesome! Thank you. Gonna take me a bit to get all the info you provided … But awesome! Thank you so much.
So… Thought I’d post an update. Had to stop part way through. Restarted with the settings above and was able to get the total time down to 2 hours. It was doing way more than it needed to and it’s because I set the profile wrong on accident. Thanks again for all your help!
Yeah. The bigger you go, the longer it lasts. This half of a small subwoofer enclosure takes quite a bit to print.
