Do you happen to have the model to share? Keep in mind if it’s large, broad, and flat, you’re printing a 0.4mm line per sweep. Most time in a print is the bottom and top layers doing full fills, taller projects with sparse infill are faster.
I would just get 1 or 2 ikea skådis boards if i were you. They’re not that expensive and there are many downloadable toolhangers for them online…
The Snapmaker 2.0 is not a fast printer. I believe it uses leadscrews with 8 mm lead?? for x and y so it cant print very fast without loosing steps…
edit: I see now that there are 20 mm versions. Hopefully you have those and not the 8 mm versions… according to Snapmaker, the 20 mm versions should be good for about 100 mm/sec.
If you must print your board(s) you could try printing fewer top/bottom layers, increase layer height, reduce the infill percentage and use high print, travel and acceleration speed.
If top/bottom layers are non-critical, which it appears it shouldn’t really be, either a single bottom and two top, or forego the top/bottom altogether. I have a habit of printing functional parts that are either flat or horizontal load bearing with no top/bottom and exposed infill. Plus it looks neat.
You can reduce your print time by as much as 80% with proper calibration and slicer settings tuning.
Example: using Luban with “Normal Print” default settings will print a Benchy in 2hrs 42min (162min). After calibrating the machine and using Cura with fully tuned settings, the same Benchy will print in 31min. That’s an 81% reduction in print time with no loss of quality. And that is using an older pre-update A350; the T-suffix model machines with the updated linear rails can go even a bit faster.
