Is there a way to have the bed automatticly heat up when I turn it on. So when I am setting up my print, it is ready to go when I send the G-code?
No, not automatically, as a safety concern. But you can manually go into “Control” and set the bed to start heating to whatever temp you want while you get set up and send the G-code.
You could create a gcode that just sets the bed to heat up. Load and run that.
But it’s probably safer and just as easy to manually turn on the bed as @Mxbrnr says.
Yeah, thats what I have been doing, just thought of skipping a step but makes sense as to the safety concern of it. Thanks!!!
