After updating the Snapmaker program and drivers, all the files I made before that stopped working. At the start, readiness instantly becomes 100%. Then it returns to zero. The laser does not work (it shows 0% power on the touchscreen and cannot be changed), and the head continues to move along the route. All the files I made after the update work.
This is very bad for me. I have files that I reuse many times. Now I will need to process a lot of files. And I no longer remember the settings for each file.
Please correct this error!!! Or does anyone know a solution.
Thank you.
Downgrade your firmware below 1.18 and luban below 4.9.
Maybe this helps you too:
I will try. But I don’t have a door.
Rolling back one version helped. Thank you.
Old files would have to be regenerated, in order to be compatible with latest firmware releases and Inline function.
How to do it ?
Build it new in Luban.
Theoretically, they should run just as they did before. I just slapped together a project in Luban 4.7.0 to make an “old” file and it worked on 1.18 fine. Are you trying to run it via USB, Luban, or internal memory?
