A350 Stopped an goes to home after short time of Start
My Snapmaker A350 suddenly stops the Projekt short after start printing.
I print the same Projekt as befor whithout changes.
Why ??
If i restart the konfiguration in luban it will run for one job.
Export your logs and share the data.
https://wiki.snapmaker.com/en/Snapmaker_2/manual/export_logs
i downloaded the new snapmaker orca yesterday and i had the same happening.
it began with the starting routine, heating up, going to the edge of the printbed and priming. after priming it stopped the print.
with prusaslicer i have no problems. even the color changes work now
SC_86.zip (863.3 KB)
I’m sharing the logs.
I have the same issue; it stops halfway through the process.
I hope there’s a solution.
Hard to say, are we talking about your 2w laser or 3dp module, which time the error occurs would also be helpful.
I see a lot wireless printing (at least I think this discover requests are from wireless connection).
And I see failed unpacked gcode .
I see your firmware is not up to date.
Update your firmware please and tell us some more stuff, especially which slicer.
Try to send the gcode to the machine and print it local.
Anyway, you could reach out to snapmaker support they are really helpful.
email support@snapmaker.com
ticket https://support.snapmaker.com/hc/en-us/requests/new
