Hey all. I’ve been seeing prints stop and the machine reset/at the start screen. If I turn the machine off, then back on, i have the option to resume (and it does so). Sometimes that’s enough, but once one a quite long print (over a day) it stopped 4 times. the print did complete, but during that time everything was still hot, just not moving. On those really bad ones where i didn’t get to it quickly, there would be a glob of filament on the print. I could snip most if it off while the machine was homing and it would “smooth” it over more/less with the heat of the nozzle. But still should be able to set and forget.
The latest firmware i did see a note (i think) about fixing random stops. That (i think) has helped, but today I did see it stop. I luckily was next to the printer and able to reset it quickly (before filament gets baked in), but again should be able to start a print and let it run for days without having to worry about it stopping in the middle of the night.
My GUESS is: like when loading a really large/long print, something is “disconnecting”. The only real errors in the logs look like this:
1680457524079,2023.04.02 17:45:24.079,ERROR,SC-FW,wait gcode pack timeout and req:1620656
hundreds of lines. the latest batch of logs shows several groups of these, requesting different lines, so essentially shows each time it stopped.
I have only ever used any of my snapmakers (original and A350) for 3D printing. But in order to get what i paid for and likely buy a new MK4, I would like to start using it for things other than 3D printing. That though means moving it to a new room cuz can’t have dust and junk in my office. But having it out in another room, I don’t want to have to worry about it much, so would like to get to the bottom of the hanging reset. Cuz if it happens on the other things (machine reset with tools still going), something like the laser would be extremely bad. The 3D and CNC less so, but still.
attached are today’s log export. I updated the firmware yesterday. (can’t check the version since i have a print going, but might be in the logs).
logs-04-11-23.zip (625.9 KB)
