Hello all, after a print is completed the Z-axis lifts up the nozzle. This works since a few weeks very, very slowly. Is there a setting for this or maybe something is wrong? BR Ringellocke
I noticed that too, although I haven’t taken the time to figure it out.
I’ve started letting it rise a few cm, then turn the machine off. Just be careful doing that, because it doesn’t lock the Z axis until it finishes the lift. I’ve bumped the print head a few time, and it nearly fell onto my print.
Are you running the latest firmware and latest Luban? I have the 1.11 firmware, but I’m not using the latest Luban.
Which Slicer did you use? - If you use Luban, which version? - May you share a little gcode-file with us or just post the end gcode?
Hi, thank’s for you fast replys!! I’m using snapmaker original firmware version “Snapmaker-GD32Base-2.11” and slicer “Snapmaker Luban 3.3.3”.
Followed the end code:
;TIME_ELAPSED:441.535422
G1 F1500 E41.1733
M140 S0
M107
;End GCode begin
M104 S0 ;extruder heater off
M140 S0 ;heated bed heater off (if you have it)
G90 ;absolute positioning
G92 E0
G1 E-1 F300 ;retract the filament a bit before lifting the nozzle, to release some of the pressure
G1 Z125 E-1 F35 ;move Z up a bit and retract filament even more
G1 X0 F3000 ;move X to min endstops, so the head is out of the way
G1 Y125 F3000 ;so the head is out of the way and Plate is moved forward
M84 ;steppers off
;End GCode end
M82 ;absolute extrusion mode
M104 S0
;End of Gcode
My next steps:
using the newer version Luban “3.8.0”
using default settings for high quality
Maybe it will change something?! :))
I am also using Luban 3.3.3. I haven’t upgraded, because my son is complaining that customized print profile changes don’t save in the latest version (completely anecdotal and untested by me). But that does make it sound like a bug that was fixed if @xchrisd doesn’t know what we’re talking about.
I am absolutely not sure, this behavior is since ever, right? (I remember, z was always the slowest axis)
I guessed the machine changed in some way and this could cause luban, because of the end gcode.
BTW, change the line above the following and see if it helps
G1 E-1 F35
G1 Z125 F100
Hi all,
I tried it again with the newer version of Luban “3.9.0” and the Z-axis moves normal!
The end code is now:
;End GCode begin
G92 E0
G1 Z125 E-1 F3000 ;move Z up a bit and retract filament even more
;End GCode end
M104 S0
;End of Gcode
The F-value, like @xchrisd explain before, was changed from “F35” to a higher value “F3000”. This fix the problem for me. Thank you very much for helping me with this issue!
Best regards
Ringellocke
