Using camera changes job setup origin
Setting center as project origin. Use camera background then look at job origin. The origin changes to bottom left!
Mine changes to upper right. Don’ t know why and don’t know how to fix it! :woman_shrugging:t5:
You mean when you start the job, it prints to the upper right. When the job origin changes to bottom left and you have used the center, the result will be it thinks the center the the bottom left so it prints to the upper right of where you think center is.
Ooohhh, I see. But when I start the job, I set it at center and list the size of the object. Then when I go to workspace and do the camera background and do the run boundary, it puts it in the upper right hand corner.
