I think some others have experienced this issue with the latest Luban version (4.2.3), not sure if there is a solution.
When I load objects they are centered on the plate but when I build the G-code and load it to the workspace the objects are always in the top right quadrant.
As a result I can’t take advantage of the full build size and also running into warping issues at the periphery of the bed plate.
Usually that means you selected the wrong machine. In Preferences, Machine Settings, double check that the machine matches the actual model you purchased.
I don’t have this issue with the laser engraving or CNC. It only seems to be happening with the 3D printing. I’ve tried installing Luban on another computer and I have the same issue.
hi sorry, but i didn’t see your video. Do you mind sharing a google drive link? You can also write an email to our support team with the video, if you find it too complicated to upload a big vide here. The email address is support@snapmaker.com.
