Hi guys,
I’ve changed the password for my home WiFi and now I can’t get connected with my A150.
I can see the WiFi network and I’m sure I’ve inserted the new password, when asking, but seems to not connect any more.
Any idea?
Hi guys,
Any idea?
No one can help me?
Never had that problem.
Change your password back? (I know that’s probably a terrible suggestion)
Try a search for password?
@WilliamBosacker really thanks for response but my problem is that I can’t connect even if I manually enter the new password of the WiFi.
It seems to me that the Snap has stored the old password for my net and I can’t update it with the new one.
Really disappointed!!!
Think I found what you need to do.
You’ll have to try it yourself. Not going to mess with mine.
Enter developer mode:
Here is the routine to open dev mode: Go Settings → About → Tap the image on top for 5 times to activate dev mode (Tap once more to inactivate dev mode). The option to disable fast calibration sits inside “Experiment” app.
You should then see an icon for “factory”. Should be able to do a full reset. Maybe there’s some wifi settings in there too.
If you do factory reset I assume you’d need to redo your extruder calibration (at least check) or any other settings you’ve done.
