Today i want to CNC a simple bunny but when i connect with WiFi next to the Printer is a yellow clock so i cant send the file. I restart the Snapmaker i restart Luban. I reset the Snapmaker. nothing works. I use Luban 3.3.3 and the Snapmaker is Firmware 1.7.0
When i put the *nc file on an USB Stick⦠The Snapmaker didnāt show the file⦠i tried different Sticksā¦
Hey, have you tried this with USB connection?
There are several threads about USB thumb drive problems, may you use the original one which came with the printer?
It has to be formatted in Fat32 with a cluster size of 8k (or less, I think).
The data has to be copied to the root directory.
There are several threads, search for USB.
Hope this helps.
Hi @FatMasterM, can the touchscreen show the .gcode or .cnc file when you use the USB disk? Please update the latest firmware. If the problem remains, please send me a picture of the yellow clock here.
This is the exact issue I have with my A250. The yellow clock symbol shows after connecting to snapmaker and the āSend to Snapmaker via WiFiā option is still disabled. I have the same issue that using USB does not show the .NC file.
