White Lines In Workspace Preview
These white lines appear once I press “export” to “load GCode to workspace”. They also show up in the final product as less pronounced lasered out lines. Not sure why. Has anyone experienced this? Any solutions? Thanks a lot!
They are travel lines. They will only show in thew final work if you forget to turn off constant power.
Thanks for the prompt response. I unchecked the “Constant Power Mode” box in the Toolpath Settings. Sadly, I am still experiencing the lasers travel lines. Is there another way to adjust this setting? Thanks a ton.
The travel lines will always show in the preview online, they should not be in the final product.
t
Ok thanks. For some reason, they still show up in the final product. This is frustrating but I’m excited to find a solution. Happy printing!
Make sure Luban and your snapmaker are the latest versions. There was a change that changes how the laser works and causes the transient lines.
Thanks Skreelink. I’ll report back with any updates.
THANKS SO MUCH EVERYONE!! Skree, I needed to update both the software AND the firmware for Snapmaker Luban.
Glad to hear you finally got it resolved. :slight_smile: Enjoy your laser.
