Hey Guys,
When I engrave with the Laser, there are some unwanted lines. First when I test the boundaries and also when the laser starts or finishes it draws a huge line. I already updated the firmware so…
Hello,
I have a similar issue here.
Have you found a solution to your problem?
Thanks.
Send us a pic of your unwanted lines please.
It looks like the laser power is too high during framing, black absorbs the laser really easy. Also are you using Luban? Make sure it and the firmware on the machine are the latest. There was a change in laser control method and causes a mismatch.
Which laser are you using?
Make sure to fully update your snapmaker AND Luban. There was a change to how the laser runs recently and keeps the laser on during travel moves if you use an older version of Luban.
Thanks i’ll check it and let you know
Skreelink
Thanks it’s working no more funny lines ![]()
Skreelink
Glad to hear that. ![]()
