2.0 Laser 10W cutting lines mark
I am trying to make a little wall art for my granddaughter and I don’t know what I did wrong. Looks like it engraved the CAM (?) lines. See image. Sorry, I still don’t know the correct vocabulary for this.
These lines do not show in the vector or preview, only the cut preview, and should not be engraved.
Double check and make sure your machine is upgraded to the latest firmware, as of writing, 1.17.17. There was a change in how it works introduced in Luban 4.9.0. So if you use the latest Luban, you must be at least 1.17.17 on the snapmaker 2.0, otherwise you get the transient lines.
Thank you so much. I am updating it.
if it works, please mark the topic as solved for others to rely on it.
