When homing the machine the x axis is making a grinding noise.
Check this video for clarity:
The linear rail has a bad or misaligned limit switch. You might be able to fix it yourself, but it’s probably best if you contact Support and attach this video.
I will do as you suggest. Thanks for taking the time!
Fixed for now. After getting instructions from support I removed the endcap of the rail to find the limit switch lever unhinged. I rehinged and it is currently working. I’m skeptical of it lasting very long but I hope I am wrong.
Thanks again!
np, and good luck! Yeah, you should keep an eye on it, because if it can happen once, it will most likely happen again. If you are close to the end of your 1 year warranty, you might want to exercise that right and get a replacement.
