What should be done about Frequently Asked (and answered) Questions?
That looks better than I expected.
I can massage my spreadsheet to generate that.
Let me post a full version here and see what that looks like.
Things to make
CNC
Added By Description External Resource
doug 2D Chinese Dragon aws1.discourse-cdn.com
George Guy [Feeds & Speeds for Wood] cnccookbook.com
Doug Parsons [Plastic Cutting CNC Router Bits] amanatool.com
Accessories
Jihun Easy Clamp for Snapmaker myminifactory.com
doug Multi Color Filament Mixer mosaicmanufacturing.com
doug Multi Color Filament Mixer youtube.com
daemionfox Multi Color Print Head newatlas.com
daemionfox Multi Color Print Head reprap.me
kelvin8r OctoPi octoprint.org
kelvin8r [OctoPi - OctoPrint Forum] discourse.octoprint.org
kelvin8r [OctoPi - OctoPrint Docs] docs.octoprint.org
Tone Nickle Plated Nozzle amazon.com
[Touchup Tool] amazon.com
[Touchup Tool Lower Cost] amazon.com
Software
Tone [Free Block Drawing Program] app.diagrams.net
Tone [Free Block Drawing Program] youtube.com
doug [FreeCAD Manual:Preparing models for 3D printing - an interesting read, especially on converting to Meshes] freecadweb.org
How To
xchrisd 3d Print Guide_Walk Through
Jameracho A350 3D Printing Bed Calibration Guide Google Doc
doug [Cura Tutorial] all3dp.com
doug [Best Glues, Epoxies, and Plastic Welds for 3D Printing - Part 1] youtube.com
doug [Getting started with Fusion 360 - a good video to start learning from] autodesk.com
doug [Fusion 360 - Tutorial for Absolute Beginners— Part 1] youtube.com
doug [Fusion 360 - Tutorial for Absolute Beginners— Part 2] youtube.com
doug [Fusion 360 - Tutorial for Absolute Beginners— Part 3] youtube.com
doug [Fusion 360 - Foundation Concepts - A series of great short video’s] help.autodesk.com
doug [Fusion 360 - How to create embossed text] youtube.com
doug [Fusion 360 - Split Face & Split Body] youtube.com
doug [How To - Avoid clogs with PLA Composites and all-metal hotends] proto-pasta.com
doug [How to Smooth PLA 3D Prints] instructables.com
doug [How to Anneal Your 3d Prints for Strength] rigid.ink
doug [How to find the perfect temperature for your 3D prints!] youtube.com
doug Painting with Oil Based Pens youtube.com
Tone [Printing with Nylon] matterhackers.com
doug Working with PLA Filament rigid.ink
doug [The Ultimate Guide to 3D Printed Text] thingiverse.com
doug [The Ultimate Guide to 3D Printed Text] xometry.com
doug [THE ULTIMATE BEGINNERS GUIDE TO 3D PRINTING] beginnersguide.io3dp.com
doug [3D Printing Tech Tips: Infill Percentage and Pattern Explained] 3dplatform.com
doug Temperature Towers - FINDING THE PERFECT TEMP FOR ANY FILAMENT youtube.com
doug [Simplify3D - Improved 3D Printing Success!] youtube.com
doug [Picking a 3D printer nozzle and installing it!] youtube.com
doug [Simplify3D - Different Settings for Different Regions of a Model] simplify3d.com
doug [Over-Extrusion – Tips and Tricks to Solve It] all3dp.com
doug [3D Printing 101: How To Fix a Clogged Nozzle Using a Cold Pull! - Suggested by James Bricknell] youtube.com
doug [Annealing PLA Prints for Strength – 2 Easy Ways] all3dp.com
doug [3D Printer Bed Adhesion – All You Need To Know] all3dp.com
doug [How to Set Up OctoPrint on Raspberry Pi 3 B+ – 3 Easy Steps] all3dp.com
Doug Parsons [TinkerCAD - YouTube Channel] youtube.com
Snapmaker [How to Use the Laser Engraving Feature?] youtube.com
Snapmaker [How to Use the CNC Feature?] youtube.com
Snapmaker Remove Blob
Snapmaker Laser settings for different materials
Snapmaker Cleaning the Linear Module
Snapmaker Leveling the Heated Bed
Snapmaker What should I do if the filament is broken in the 3D Printing Module?
Snapmaker What should I do if the first layer does not stick to the heated bed?
Snapmaker What should I do if the laser engraving module cannot work anymore?
doug [The Best Way to 3D Print Threads; Nuts, and Bolts] youtube.com
doug [Step-by-step easy guide: designing and 3D printing threads] sculpteo.com
doug [3D Printing Threads and Screws – A Simple Guide] all3dp.com
Edwin SnapMaker Original Repair Tutorial
Source code
Snapmaker Announcement github.com
Tone [G-code Wiki] reprap.org
Tone [G-code Wiki] marlinfw.org
Tone [Releases - The most current Luban] github.com
Snapmaker [Snapmaker G-code Google Docs Reference (incomplete)] docs.google.com
Troubleshooting
rojaljelly [Troubleshooting] aprintapro.com
Miscelaneous
Tone [36 Colors PLA - 16’ each - Includes 6 Glow in the dark] amazon.com
doug [3D Printer Nozzle Comparison Guide] matterhackers.com
jstncrft Filament Tube amazon.com
doug [ABS Bed Adhesion Tips & Tricks] matterhackers.com
rojaljelly [Filament Properties Table] simplify3d.com
doug [Free ‘Beginner’s Guide to 3D Printing’] i.materialise.com
doug [Complete 3D Printing Filament Comparison Guide - 2018] rigid.ink
doug [PLA Filament Guide 2018 – Explained & Compared] all3dp.com
doug [Complete 3D Printing Filament Comparison Guide 2019] rigid.ink
doug [Print Quality Troubleshooting Guide] simplify3d.com
doug [Reviewing 30 different filaments!] toms3d.org
zeveck USA Made PLA – looks to be good quality PLA makergeeks.com
doug [Starter Temperatures & Printing Guide] filaments.ca
doug [Octin Stencil] dafont.com
doug [Octin Prison] dafont.com
doug [Ultimate 3D Printing Materials Guide] simplify3d.com
doug [When should you upgrade the nozzle in your 3d printer?] youtube.com
doug [The 3D Printer Filament Recycler’s Guide] all3dp.com
doug [Laser Safety] wickedlasers.com
doug [3D Printer Nozzle Size & Material – What to Know & Which to Buy] all3dp.com
404 Error
Tone SparkMaker – SLA printer shop.ogadget.com
That’s hideous to actually edit if you don’t know what you’re looking at.
It looks good and works well but can anyone edit it without screwing it up?
That is precisely my current biggest concern.
The alternate versions we’re playing with aren’t really any better either.
I’m wondering if using indented lists with headings for sections might be a more robust way to go.
I don’t want to make more work for anyone either, so I’m trying hard to figure out what a longer term solution might look like.
How about something like this? (not fully formatted everything just as an example:
Things to make
Dust shoe: don't get all dusty
  • Description....: description of the item
  • Resources......: Some link
  • Submitter......:
Gift box
  • Submitter......:
Surprise item
  • Submitter......:
General tips and tricks
Bed calibration
  • Submitter......:
first installation
  • Submitter......:
Filament tips
  • Submitter......:
The code for the segment above looks like this:
### Things to make
[details="Dust shoe: don't get all dusty"]
  * `Description....:` description of the item
  * `Resources......:` [Some link](https://www.snapmaker.com)
  * `Submitter......:`
[/details]
[details="Gift box"]
[/details]
[details="Surprise item"]
[/details]
### General tips and tricks
[details="Bed calibration"]
[/details]
[details="first installation"]
[/details]
[details="Filament tips"]
[/details]
I’m abusing the inline code tags and dots (.) to create to align the colon as whitespaces get filtered out. But the code tags do enforce a monospace font which helps to align.
If someone wants to add something to it. They just have to add a section like this which is fairly easy to understand:
[/details]
It’s more or less abusing the hide details tag as a list item. You could nest them, but you can’t style the description of them which is a pity. Would be great if you could add ## to them to make them like headers
Main disadvantage: you need a lot of clicking if you want to see more details. You could decide to not use the hide details option at all, but that would make it very long.
Main advantage: very easy to understand and edit. Just include a sample in the post that can be copy-pasted and it’s really easy to fill in and mistakes can’t really wreck the entire post. If later one it would be preferred to have more than just the description, link and submitter: it can easily be done without the need to update the entire table all at once, “easy” to reorganize and use the other markup possibilities
edit: little bit of cleanup
I received a badge yesterday for being a “regular” which apparently provides me some powers. (renaming threads is the only one that sticks out to me but maybe something else too) That implies they do have the ability to provide some.
We could inquire if pinning can be granted or not? @staff
Actually the original wiki-page by Tone is already pinned, just not forum wide, only in the getting started category.
Pinning requires staff action. I had to ask to get it pinned.
Keeping everything in one thread strikes me as a way to end up with one heck of an unwieldy thread (and possibly make the forum software explode somewhere along the way). And if they switch the forum software again, we might lose everything.
Alternative 1: Get multiple threads pinned (“Assembly/Getting Started”, “3D Printing”, “Laser”, “CNC”, “Troubleshooting”, “Accessories to Make”, “Other Things to Make”, etc.). Doesn’t fix the potential problems with backups.
Alternative 2: Set up an external wiki—I agree that the weak excuse for wiki software that github provides is not an option, but there are hosts that will provide instances of Mediawiki or similar for free. miraheze.org looks nice enough and seems responsive; there are others. This requires an ongoing mass information-transfer exercise.
Alternative 3: Keep the single FAQ thread, but curate it to within an inch of its life. Don’t include any “stuff to make” that isn’t a Snapmaker accessory, but point people to an external collection on Thingiverse or somewhere. Don’t include any questions that haven’t been asked at least 3-4 times by different people. And so on. Hopefully this would stay small enough to make it reasonable to save copies off periodically, but it would require the cooperation of everyone working on the thread.
I really like the idea of a “FAQ” category at the top-level of the Forum (to use the existing terminology) with a pinned post for each section and in that we maintain a list for the various things of interest related strictly to that area. It means that as new areas open up, like say the rotary module, we can add another pinned post to that category.
I wonder if the FAQ category could be configured to only contain pinned wiki posts that cannot be replied to, which would make the noise level much lower. My google-fu didn’t unearth the magic discourse incantation to make this happen.
We could implement this using a policy of “links to the forum only”, so if someone wants to add a reference to an external resource, it must first be posted as a forum link, which would allow discussion related to that resource in that thread which would make the item continued to be relevant and if the link dies, there could be a reply to the source post with a new link, keeping the FAQ still correct - less maintenance work - yay!
As for backups, I run plenty of daily backup jobs for various things, adding a few URL’s for backing up is pretty simple.
I wasn’t here with the previous forum, but I’d be surprised if the data didn’t still exist somewhere. Perhaps we could ask SM for it?
Back to formatting. It could be a simple indented list if we have a FAQ for each category like this:
Assembly / Getting Started
The resources listed here are forum posts that help a new user assemble their SnapMaker device and configure it for first use. If you have questions about a resource here, respond to the original resource post so the whole community benefits from the discussion.
# Assembly / Getting Started
The resources listed here are **forum posts** that help a new user assemble their SnapMaker device and configure it for first use. If you have questions about a resource here, respond to the original resource post so the whole community benefits from the discussion.
* [3d Print Guide_Walk Through](https://forum.snapmaker.com/t/3d-print-guide-walk-through/5945)
* [A350 3D Printing Bed Calibration Guide](https://forum.snapmaker.com/t/a350-3d-printing-bed-calibration-guide/12019)
If that is a suitable idea, this leaves the question, which “pinned” post areas should the FAQ category start with?
@ElloryJaye has proposed:
  • Assembly / Getting Started
  • 3D Printing
  • Laser Cutting / Engraving
  • CNC
  • Troubleshooting
  • Accessories to Make
  • Other Things to Make
@Tone used:
  • Things to make
  • CNC
  • Accessories
  • How to’s
  • Source code
  • Troubleshooting
  • Misc
I suggested:
  • Software
We can vote using a poll, but are there any suggestions on categories that would be helpful in our first attempt at doing this?
Good morning, I like this FAQ idea.
I have no idea which categories could be added, so far, it looks complete.
The topic you are going to create, should be a wiki-topic anyway, so editing is possible forever. I didn’t knew this at my getting started topic and can’t edit it any more…
:+1:
I’ve been thinking about the categories and the kinds of questions that come through the forum on a regular basis. Here’s a list based on my observations:
  • Putting your SnapMaker together
  • Instructions and User Guides
  • Troubleshooting when things don’t work as expected
  • Maintenance of your SnapMaker
  • Getting Support
  • How shipping works
  • Software
  • Accessories for your SnapMaker
  • Models to make
  • Source Code
  • Reporting Bugs
  • The 3D Printing Module
  • The CNC Module
  • The Controller
  • The Laser Module
  • The Linear Modules
  • The Power Supply
  • The Rotary Module
  • The Touch Screen
One of the issues with the above list is that there is overlap - and therefor scope for confusion. I’d rather have specific, distinct, non-overlapping areas. It’s likely that this isn’t possible, but would love to hear feedback on it.
I did toy with just having sections named after the hardware components only:
  • The CNC Module
  • The Controller
  • The Laser Module
  • The Power Supply
  • The Rotary Module
  • The Touch Screen
Perhaps that’s a better starting point?
I prefer just the hardware but add maintenance and software.
Not sure power supply or controller needs their own. Maybe combined with touch screen.
The only other category I think might be good, but maybe that’s under each of the modules would be a “To Start” guide.
what if we started an offshoot forum “For Newb’s Only” so that us newb’s such as myself dont feel so guilty for asking questions which im sure you guys who have been around for a bit have heard a thousand times and bog down the forum for more advanced issues and situations?
For the tutorials for the very beginners:
For the frequently asked question, see this site
If you are worried about asking questions that you feel are very “newbie”, just post within the “getting started” category. That category’s stated purpose is to “get help from fellow creatives” so it would be a good match for what you describe.
If it helps, I have spent an embarrassing amount of time reading through the forums, even before making an account, and I haven’t really seen much negative sentiment about people asking questions. I’d just recommend using the search function to see if there is a thread that already exists that relates to your issue, both so you can try fixes before having to post and wait for a response and to try to reduce clutter on the forums.
Overall, a lot of us are still learning our machines and are happy to help!
I don’t think you need to feel guilty about being a beginner.
We all don’t know what we’re doing at first.
We’ve all been beginners at one time or another.
I may have been wrong in some other way.
Please forgive me.
thank you! I appreciate your patience…
The above file has been removed from the google drive.
