When I try to update the firmware, it does it but then starts again.
Not sure what to do.
if you got new machine. Make sure you have printer head installed. I went grazy because i wanted to start with a laser. it will just crash if you dont make main update with printer head.
J’ai réussi! il faut débrancher : Bouton d’urgence, tête, enclosure. Vous aurait accès au paramètre, et redéclencher une mise à jour du firmwer, et refaire les mises à jour.
I succeeded! you must disconnect: Emergency button, head, enclosure. You would access the setting, and re-trigger a firmware update, and redo the updates.
hi i have the same problem it only happened on one of my 3 printers
