Can we please get adb access to the android controller, especially for the reason to run “adb logcat”. My SM2.0 keeps having WiFi issues and having to use a USB Ethernet adapter sucks. With adb logcat there’s hope I could at least get some logs and find out why.
Add an option to start the print after sending it to the controller. I have my SM2.0 in the garage which is the other end of the house, which means a lot of running back and forth. I prefer to print from the controller instead of Luban since I don’t want to lose the print should my desktop reboot (looking at you windows update). I’m fine with the initial connect wifi auth screen, that makes sense, but after sending it, I should be prompted if I want to start it and perhaps a confirm screen where I agree I understand that the printer must be ready to be used (no obstructions, etc) and that SM takes no responsibility for things going south.
regarding 2…
not that i recommend this, but you can just hit the play button from luban to start printing.
however, you will not have power loss or filament runout recovery.
You’re more likely to get feedback from the dev team by adding an issue on github: Snapmaker · GitHub
I wanted to, but the github area doesn’t have a repo for the actual display/android device, only the firmware that controls the actual modules. And these requests are for the android part.
So I guess I might as well request the repo for android so I can build my own controller software
They promised to make it available in the (near) future. For now I would add those requests to the Luban repo.
