It’s totally annoying that if I connect using Luban to the printer, then disconnect, printer popup says lost connection, but only choice is to cancel the current job. Totally useless. I want to be able to check periodically about print status via Luban, but doing that makes the printer-local display useless. At a minimum, add a ‘keep printing’ button. BTW, ignoring the printer and just closing the Luban app causes no problem. Reconnecting causes no problem. This is just a lame firmware issue on the printer side.
Agree, same issue today. Had to restart a job a couple of minutes before it was finished.
SM staff is pretty non-existent on here other than when they post software updates or announcements.
Bugs should be reported at Snapmaker · GitHub under the relevant section.
