Touchscreen failure, need to level bed to use luban
My touchscreen failed. I’m told that the new touchscreen has been ordered but it hasn’t been shipped. I received 3 months worth of satisfactory production from my 2.0 but then the print module failed. A replacement arrived, but then the touchscreen failed. I need to get some production out of this machine and I could print via luban, if I could just level the bed.
The bed is very low on the left and very high on the right. Is there a way to use console to clear bed settings, then to run bed level without the touchscreen?
If there isn’t a way somebody better get on that. Some of us have work to do.
You can use the Console and Control panel on Luban to level your heated bed (5×5 Auto Mode) by the following steps:
  1. Connect the machine with Luban via the USB cable.
  2. On the Console panel, enter G1029 P5.
  3. Enter G1029 A. The auto-leveling process will start.
  4. After the leveling process ends and the toolhead stops moving, adjust the height of the toolhead with the Z+ and Z- buttons on the Control panel and calibrate the Z offset with the provided calibration card or a piece of A4 paper (as instructed in the QSG or UM).
  5. On the Console panel, enter G1029 S0.
  6. Enter M500.
This is so good.
You’re a lifesaver Riskey.
Thank you!
It’s running beautifully…
