Suggestion for replacement A350 print sheet
Snapmaker is now only selling the Double Sided Printing Stickers in Australia and the UK. I am in Japan and cannot purchase one.
I recall some of you mentioning some glass ones in the past that were much easier to achieve a good leveling with, but I cannot seem to recall the details.
Mine is 5 years old and in pretty bad shape, gouged, warped, you name it. I consider it consumable and it has been consumed. I can print small things no problem, but large area prints will fail due to inconsistent leveling, which honestly has always been a problem. I did get better after Snapmaker acknowledged that the original beds were out of tolerance and sent me a new one.
I would recommend a PEI bed; they have great adhesion and release finished prints very easily.
I bought a 350x350mm PEI bed on AliExpress for $15 and cut it down with shears; it is a little smaller than the normal 335x365, but it works fine.
https://www.aliexpress.us/item/3256805383220887.html?spm=a2g0o.order_list.order_list_main.5.13801802kv1yOE&gatewayAdapt=glo2usa
There are also some PEI beds for Snapmaker printers (they are more expensive, though, around $50)
https://www.aliexpress.us/item/3256809499654687.html?spm=a2g0o.productlist.main.2.1667BZEdBZEdrZ&algo_pvid=f08c71a6-4a4b-4299-beb8-2b7ffec110c0&algo_exp_id=f08c71a6-4a4b-4299-beb8-2b7ffec110c0-1&pdp_ext_f={“order”%3A"36"%2C"eval"%3A"1"%2C"fromPage"%3A"search"}&pdp_npi=6%40dis!USD!57.75!23.68!!!57.75!23.68!%402103128817724122937546723edefb!12000049857874292!sea!US!3606715368!X!1!0!n_tag%3A-29919%3Bd%3A359d1cfb%3Bm03_new_user%3A-29895&curPageLogUid=SEDN05rKB4zc&utparam-url=scene%3Asearch|query_from%3A|x_object_id%3A1005009685969439|_p_origin_prod%3A
PEI build plate for Raise3D Pro2 fits ideally, you just need to remove plastic handle from it.
